Jul 31, 2016 at 5:27 PM Post #4,685 of 7,931
That's too bad, Imo, and many others here, the FLC8S' many sound possibilities alone is worth keeping the earpieces themselves and experiment with other cable solutions, if money isn't of a concern of course. I agree the stock cable is horrid but the monitors are fantastic with a more suitable option.
Jul 31, 2016 at 5:44 PM Post #4,686 of 7,931
returned mine. cable is way too loud. sounds like i'm in a storm.
Good to remind people that came cable microphonics have been discussed extensively both in this thread and in reviews as have alternative cables, such as the older FLC8S cable. It's easy enough to purchase the older cable directly from Teo at LMUE when ordering your FLC8S, or you can purchase an aftermarket cable. At this level of performance and bang for your buck, purchasing an aftermarket cable that better fits your needs is a minor inconvenience IMHO. Just my two cents...
Jul 31, 2016 at 7:06 PM Post #4,687 of 7,931
Returning it because the cable is bad is just too bad IMO. You can even replace it or ask for the old cable, the blue cable is not THAT microphonic, I've heard worse. The sound is very worth keeping, even with stock tips the mids are so good.
Jul 31, 2016 at 8:39 PM Post #4,688 of 7,931
The sound is a must keep unless u have totl iems
Jul 31, 2016 at 8:48 PM Post #4,689 of 7,931
I'm lucky, I guess, as I have no issues w my blue cable...
just looking forward to the spintips to improve fit and sound
....still dislike the memory wire.
Jul 31, 2016 at 8:55 PM Post #4,690 of 7,931
Here's a fun fact. My pal's TF10 cables gave up on him and I gave him the original FLC8 black cable as a replacement. Fits like a glove.
Aug 1, 2016 at 6:24 AM Post #4,692 of 7,931
Hmm, lots of negative comments re the noisy cable ... FLC are not the only IEMs with cable noise .... does not need to be such a big deal, considering the fantastic sound.
I used the blue stock cable, now the black silver cable .. have bought a 3mm rubber washer from the hardware shop (the 2mm was too difficult to get across the plug) -- which makes an effective and cheap chin slider... microphonics reduced to a minimum. Love the flc !
