Arysyn
Flares Pro just sounds like that. You don't have a faulty unit. I've had two Flares Pro (and send one for check-up). Some people (many actually) just don't pay attention to some things in sound and don't listen closely enough.
First of all - I've tried many different sources and the truth is nothing sounded as good as their bluetooth module. Of course, bass was tightier and more impactful on some of them, etc. but as a whole the bluetooth module is best I've heard.
Second, choosing the right tips is extremely important. Comply's are best to eliminate your problem but at the same time, they take away a bit of clarity, texture and make soundstage smaller... INAirs are a quite good compromise - somewhat smoothing the harshness (not completely though), without taking anything away that much.
Same goes with Flares Gold. Unfortunately "the tizz/fizz" is still there - it's the same driver after all but it's better to some degree. Fortunately, with Comply's it's completely gone and this time without the downsides like with Flares Pro.
I don't have many sources right now to test Flares Gold wired but with Shozy Alien+ (class A amp section) and Sabaj DA3 (cheap but great DAC/amp - I like it better than Mojo or Oppo HA-2) it sounds worse than with bluetooth module. Same goes with Sony WM1A or Galaxy S8+.
For long sessions I still prefer R2pro's. I think they're the best IEMs from Flare and my favourite IEMs on the market (sadly no longer on the market). Not as good technically as PROs and GOLDs but still great and much more musical and natural sounding.
Good post, awayeah, but one thing I differ from your assesment of the FlaresGold is the fizz/tizz noise, at least on wired. When I listened through the Bluetooth recently, which was quite a bit after I wrote my review as I didn't want confusion between my opinions regarding wired vs wireless quality, I noticed some of the noise returning, but the Bluetooth was also a bit boomier in terms of bass. However, I don't think the problem is associated with the same issue as with what happens on the FlaresPro. Wired FlaresGold completely eliminates that issue from wired FlaresPro.
However, that doesn't mean that the treble on the FlaresGold is completely different than the FlaresPro. The tuning is still to create a live sound environment, but what I suspect has been done differently is the upper treble bump lowered, while Flare may have increased the middle treble and lower treble slightly to compensate. I won't know this though for sure without seeing a frequency response measurement for it. Also, I didn't get a thorough listen to the FlaresPro treble to determine whether it has the 3d spacing atmosphere to it the FlaresGold has, because of the static I believe is caused by the upper treble hump.
Regarding the latest discussion of sources and recordings, while I'm not sure what majo is listening to in getting the fizz, all the recordings I listened to were from uncompressed Flac, some also both that and on Tidal Hi-Fi, where I listened to both versions. I used a few different sources when testing the FlaresPro. All produced the same results. The FlaresGold I only listened to on the Meridian Explorer2 and recently the included Bluetooth module. I noticed several differences with Bluetooth, which was far worse than using wired through the ME2. I simply cannot recommend Bluetooth.
