Arysyn
@Arysyn your graph is what you want or what the Re800 measure?
Hi barondla,
The graph I posted here with the labels describing the various regions of the audio frequency response, is a graph I hired a graphic designer to draw, based on my specifications of what my ideal sound signature preference is. While it isn't quite so curvy-like in regards to that common aspect of audio frequency response graphs, it gives a general idea of it and I believe it does so quite well!
I'd love for it to someday get attention from a manufacturer and perhaps invite me to help them design an iem earphone based on this. I would learn a lot from the process of visiting the office where the design and tuning take place, being present step by step going through the necessary preparations of tuning and development of the driver design. I 'd prefer the physical design to be a bit longer than the Flares Pro, but generally the same bullet design, which I like best.
My sound signature is pretty much what it looks like though. While the small sub-bass hump of the FlaresPro graph concerns me, being its definitely not in my preference design, I'm thinking perhaps it won't be so bad considering the remaining bass of the FlaresPro mostly is slightly below neutral, sloping upwards through the mids, and having the vocals at the high point, along with the lower treble.
These are very similar aspects in contrast with my preference, and clearly are an advantage compared with the HiFiMan RE800. Flare Audio mentioned they are going for a live sound with these, so I'm assuming the fairly equivalent treble to bass will be plenty detailed and spacious, though I'm curious how this is going to be compared with the RE800, which has a bigger looking treble in the audio frequency response graph which Head-Fi Moderator, Brooko, produced.
Brooko's graph is very accurate in general, but I question HiFiMan possibly doing some slight alterations in tuning between regions. The RE800 I have, when not having its tuning altered by the Meridian Explorer2 I have which decreases some of the bass quality, along with slightly enhancing vocal forwardness and treble detail, otherwise without the ME2 my RE800 has less treble/neutral to slightly recessed vocals and more bass quantity than Brooko's graph shows. So either my RE800 has a slightly different tuning, or as some here have suggested, possibly the air vent is being blocked in my ears, which alters the sound in this way.
Anyways, I'll post Brooko's graph of the RE800 here, and the graph HiFlight posted of the FlaresPro, along with my graph again for direct comparison.
