mochill
Yes on estron cable on the r2pro
Fwiw I am now up to the r2pro/r2a combo after that review. I can see both being beneficial to me. The A's for casual listening and the pro's for audio work. Almost wish there was a pro/s combo. I'm a bit worried about durability of aluminum. I can be rough on stuff sometimes.
I am getting all 3. The plan is to spend a week with each, pick my favorite, give one to my girlfriend
.......and sell the last one. Very excited about them!
This is how I understand it, using a couple of pictures from the web (which are not necessarily to do with driver asymmetry but actually effects of some filters on processed audio causing waveform asymmetry - same graphic representation though) :
This is the waveform of your audio. When it is replayed by a driver, then lets say positive amplitude is the forward movement of the driver and negative backwards movement. In free air, a driver diaphragm will move kind of evenly about the baseline. That's a simplification for sake of explanation (some drivers will be asymmetric in their movement anyway due to design).
When you have uneven pressures either side of the driver diaphragm like in a headphone or speaker, it is going to be able to move more into the lower pressure area whilst the higher presure side will dampen its movement. So then you end up with an asymmetric waveform which look like this:
See how it moves more into the positive than the negative.
Now, from what I understand, this doesn't have much effect when it's an electrical waveform on your computer screen. BUT Davies is saying it has a BIG effect when it's turned into real air pressure wave asymmetry hitting your ear drum.
Your ear drum is pushed more in one direction than the other, a net pressure in one direction - that's not what free-air natural sound does, sounds like distortion to the ear, causes listening fatigue and also brings you closer to hearing damage. Thinking about it, looking at the picture, it will cause your ear drum to move in one direction as if getting battered by a loud sound whilst the average loudness remains apparently fine and comfortable..
That's the basis of the theory as I understand it. With a sealed iem especially and any headphone I guess with air pressures up against your ear, it's going to be more of a problem.
@ Ivan Diepart:
Hi Ivan,
Thanks for your comment.
The cables for these first R2's are already in production and the people who have been testing them for the last few months have all said they are great. We wanted to use TPE cable as it's so flexible and easy to wrap up into the case.
Future cable/driver assembly's will be announced later on this year to suit different tastes and the cost will be from just £35!
So what you're saying here is that the Flare Audio R2 pressure-balanced design could prevent hearing loss? Or am I misinterpreting this theory and your analysis, thus 'proving' that the pressure-balanced technology will improve sound in general but will have a negative effect on the balance and pressure on the eardrum?
Prevention of hearing loss was a major factor for me to back the R2's just as it was for the ADEL technology, hoping for game changers
I am getting all 3. The plan is to spend a week with each, pick my favorite, give one to my girlfriend and sell the last one. Very excited about them!
