Wodgy
- Feb 24, 2002
First off, you can probably reduce the audible distortion (that's what the treble harshness is, mostly) by not upsampling the signal to 192kHz. There's no reason to do this with your card. The software upsamplers I've seen are not ideal and could be introducing distortion.
Next, while the description of the Shibatch equalizer on their website sounds quite good, it's possible that the implementation is poor. It's very odd that there be any sound change if the equalizer is activated but flat. You may want to try another equalizer.
It's also possible that the Winamp pipeline may be imperfect. Does Winamp 5 use a floating point pipeline or an integer one? If you're going to be EQing and looking for better accuracy/sound quality, it may be worth switching to Foobar just for that reason. According to the Shibatch website, their EQ uses a 16383th order FIR filter and yet only uses 10% CPU time on an old Celeron. That strongly leads me to believe that the Winamp pipeline is just integer based. One of the advantages of having a computer-based source is you can easily do floating point (rather than just fixed point) arithmetic. Take advantage of that.
