First time IEM buyer, and I would like some help on deciding which pair of ear buds to get. Please help!
Jun 30, 2008 at 5:17 AM Post #2 of 3
voicemaster
Well if you live in USA i suggest getting Denon AH-C551 ($66) at amazon from their 3rd party seller. If you can't stretch your budget for C551, then i suggest the JBL reference 220, not to bass-ish, good treble and mid. You said you don't want an overly bass-ish IEM, and i think Creative EP-630 won't be a good choice there. I own one myself, although the bass will settled down after burn in process, still it's a bass heavy IEM. I don't know about the other earphones you were looking (Scosche, Philips), so i can't comment on them.
Jun 30, 2008 at 5:23 AM Post #3 of 3
Ryan41488
Thanks for the reply. I have heard of Denon actually, and I'll look more into them. My original plan was to get the JVC Air Cushion ear buds, but I heard on this forum that a couple of users said their was a lot of base to them.
