First real headphones (Grado SR60i), but not quite loud enough with onboard sound
Dec 29, 2012 at 4:36 AM Thread Starter Post #1 of 16
simon311A
So these are my first decent headphones, and so far, I'm loving these headphones. But, they are way quieter on my desktop than on my laptop.
For example, when I drag the windows volume to 100, it makes the 'ding' noise, but it's not nearly as loud as on my laptop (maybe equivalent to 30 on laptop). Another example is, my mechanical keyboard drowns out music/skype a lot of the time if it's quiet (even at 100 volume).
I'm wondering if this is because of the onboard sound (ALC898 on an Asrock Z77 Extreme4 vs Cirrus Logic CS4206A (AB 77) on my Macbook Pro), or if this is not typical and I'm doing something wrong.
Either way, what are solutions I'm looking at? Thanks for any help.
Dec 29, 2012 at 5:00 AM Post #3 of 16
Sounds like the desktop just doesn't output as much power - not surprising, it's a line driver. A headphone amplifier would let you set things loud enough to blow your head off.
Ok forgive me, I'm still very new to all this. So I definitely want a headphone amp, not a sound card or a DAC (not sure where this fits in?), or anything else? Is there a thread somewhere with amp recommendations?
Dec 29, 2012 at 5:20 AM Post #4 of 16
A soundcard would work too, if it had a headphone driver built-in (a lot of the Asus and Creative cards do). A DAC is not needed here - that's a digital to analog converter, it sits between a digital audio source (like a CD player) and an analog sink (like a stereo preamp or a headphone amplifier) - your PC already has that built-in, and so would a new soundcard.
IIRC one of the ~$30 Asus cards actually has a competent headphone driver built-in, pity is that I don't follow the Asus soundcards. Try in computer audio (just skim around) - Xonar DX or DG or DS or something like that. :xf_eek:
Dec 29, 2012 at 5:26 AM Post #5 of 16
Heya,
Fiio E10 ($45) will solve your issues and work on any machine and travel with you.
Very best,
Dec 29, 2012 at 5:51 AM Post #6 of 16
I see, thanks for the help :)
I think I'll go with the FiiO e10, since it will work with my desktop, macbook pro, and with my galaxy S3 (I think?).
Related question, is there any lag that might affect gaming by using a USB DAC/amp rather than a PCI one?
Dec 29, 2012 at 6:40 AM Post #7 of 16
Hi,
There should not be any lag of sound when using a DAC or amp.
Also I hope you like your E10, don't forget to tell us.
Andre
Dec 29, 2012 at 9:44 AM Post #9 of 16
for pure volume purposes something like a fiio E6 would suffice, but i havn't heard the E10 before though so i can't comment about the quality amplification powers of it. (though i suspect it would do better since the E6 has almost zero quality improvement qualities from what i can observe)
Dec 29, 2012 at 9:57 AM Post #10 of 16
E10 doesn't work with the s3. It's also terrible for fps gaming. Sound positioning is absolutely nil. If it's just to hear sounds, it'll be fine. The e10 does great with music tho.
Dec 29, 2012 at 4:35 PM Post #11 of 16
Did some research, looks like the ALC898's DAC is just as good as Xonar DG's DAC. So, I should just get an amp only, it seems.
Edit: Looks like the DGX is better than the DG though? Not sure. http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052
Dec 29, 2012 at 7:06 PM Post #12 of 16
I suppose you must be gaming considering that mobo? Then do yourself a favor and get the creative sound blaster x-fi titanium HD
Jan 10, 2013 at 4:52 PM Post #14 of 16
Just an update in case anyone was wondering:
I thought about my issues, and a main reason why I felt the Grados were not loud enough was because of my computer fans and my mechanical keyboard. Combine this with the fact that people on Skype said they could hear an echo of themselves made me realize that I needed a closed headphone.
Therefore, I returned the Grados and got myself a pair of KRK KNS8400s. These are nice, a lot more comfortable too - comfort is a huge issue for me. Being closed really did fix many of my problems. Their accuracy and decent soundstage make them nice for gaming too (though I don't really play FPS).
I still have to have my volume at 100% for Skype, so I do plan on getting either an amp or a DAC/amp.
e6 - Can this lower sound quality?
e10 - Is this any better than Realtek ALC 898 (supposed to be really good)?
e11 - Can't be used while charging?
Any other budget options?
Jan 10, 2013 at 10:11 PM Post #15 of 16
all i can say about the E6 is that it doesn't really boost quality, just volume boost and 3 eq settings
