Juergen
- May 13, 2003
I'm up to stage 6. in Tangent's Step-by-Step Assembly Guide - "Test the power supply". I have applied power, LED lights up - good sign
. Now the guide says:
"Power the board up and measure from the virtual ground plane to the power pads at the op-amp sockets, and at one buffer socket in each group. The voltage magnitudes should be nearly equal.... "
Are the power pads the V+ pin on the chip socket or all the pins? I'm not sure what points to measure.
