"tone" problem update
I suspect a fair amount of the reported problems are due to noisy, bad quality or under powered USB hub. Note that even when you plug the uDAC-2 to your laptop directly, internally it has USB hub.
There might well be defective uDAC-2 out there that cause high pitch and loud "tone" problem, but so far we don't have any units returned to us.
The one and only tone problem we have received in the USA (and hundreds were sold here) is posted on our help desk and has been resolved:
"There is a quite audible high frequency tone in the background on my uDAC 2 (and I've seen other people with the same problem in various forum threads). I've tried with two different computers and it's the same on both computers. My guess would be that the problem lies in the uDAC 2 and not the computers. The tone appears when the uDAC 2 is turned on and remains constant in volume no matter how high the volume is turned up on the unit itself. I've tried with two different headphones, 32 ohm Beyerdynamic DT770 and 16 ohm Denon AH-C751. The tone is a lot louder on the 16 ohm ear plugs, to the point that it's easily audible while playing music on low volume."
The customer later replied:
"Hi, I've bought a USB hub (actually to try to rule out psu/mobo in the other problem I mentioned), and when connected through the USB hub, even if it's the same port, there is no tone (and no popping sounds either). I'm not quite sure why this is, however."
When using non-powered USB hubs, the power is drawn from the USB controller. The amount of power that can be drawn from the controller is rather limited.
Non powered USB hubs are nice for mobile use or when you just need a few small devices on the USB bus, but they have a downside. Although modern software (like Windows XP) detects when you are "overloading" your USB bus, some hardware can't take it and becomes unstable. Although this isn't common, it's wise to use powered USB hubs whenever you can (unless you have good reasons not to, such as for mobile use).
uDAC-2 works in most laptops and desktop computers. But in a few cases, due to the design of USB ports on your computer, or the usage, you should use a powered USB hub (and get a good quality one).
If you are from Sweden, we are waiting for the "tone" units. If you are from any other countries, please contact us. At this point, we have no other report of tone problem from anywhere else (other than the one problem from USA as reported above but resolved with a USB hub). Again, it is very important that you contact Nuforce support directly. The more feedback we have, the better we are at addressing customer's issues. Posting your problem here is fine, but won't help our support staff unless I come across it and report to them.
