First impression of e2s - and a question
- Thread starter chazas
Oddball
- Oct 10, 2003
- Messages
- 1,861
- Reaction score
- 10
I say yes, you'd be surprised how much earwax will lodge itself in the earphone otherwise, even with clean ears. Put on the wax guards. You don't think there's enough bass? Hm..maybe more burn-in. I've always thought of the e2s as not lacking in bass...maybe not the best bass, but fine nonetheless. Congrats on the Shures and try to resist the urge to upgrade to the higher models...for now.
Originally posted by chazas My real question, if you've gotten this far, is whether the little sticky wax guards are really necessary. |
RunsWithScissors
- Sep 13, 2002
- Messages
- 349
- Reaction score
- 1
I owned the E2 for 8 months and would say that YES the wax guards are important. As long as you keep the sleeves relatively clean and free of wax, the wax guard will last a very long time so the set that you got with the E2 (assuming you got the whole fit kit) will most likely last you for years. I only replaced my wax guards once during this time - when I sold them!
The wax guards will do a good job of keeping wax and other stray debris (pocket lint, etc) out of the main body of the earpiece so in my opinion - just use them.
And clean your sleeves occassionally too! Or at least replace your foamies when they get visibly grungy - don't try to wash them or prolong their life - they are meant to be disposable. Mine usually lasted almost one month with daily use. ymmv
Better safe than sorry.
DJGeorgeT
- Mar 5, 2004
- Messages
- 2,835
- Reaction score
- 21
The wax guard may or may not be necessary. They do not serve any accoustic purpose other than to prevent ear wax to get into the pipe. If your ears do not produce much wax, you may get away without them. My ears do not produce much wax and for so far I do not see any wax on the wax guard. You can get them straight from Shure
Originally posted by chazas My real question, if you've gotten this far, is whether the little sticky wax guards are really necessary. (I searched and didn't find anything on this topic.) They're tiny, hard to deal with, likely to be misplaced, and don't appear to be easily available on eBay like the foamy tips. All in all, just a PITA to keep on hand. Any thoughts? |
As far as the bass goes, it just takes some break-in time. Mine really didn't open up until the 3rd day of listening to them pretty rigorously. Also, if you think you get a good seal with the medium tips, try the larger tips for the hell of it.
I was in the same boat and realized I got an even better seal with the larger tips.
