snyper1982
- May 23, 2005
Okay, this is my first attempt at an amp, and this is starting to get frustrating. I have looked over all my solder connections, and I didnt see any bridges or anything. Anyways, on to the problem. When I try to listen to either left or right channels individualy I can still hear sound from the other channel. I have no idea what is causing this so any pointers are greatly appreciated. I checked out the DC offset, I think I did it right, go from the virtual ground to the left and right ouputs. Well anywasys, the measurement i got was like .175 volts and like .170 volts. Anyone have any ideas what the problem could be?
-edit-
Ok I tried the DC Offset thing again, and its wasnt nearly as high as it was before. Do you have to have something playing when you measure it, or can you just turn it on and measure it?
-edit-
