normie610
Ow. Ok then, that sounds better. But if you can post a picture when you get it, would be nice.
Sure will do
Did you buy just the O module or all 4?
Received the Atom O module today. Looking forward to spending some time with it and reporting back soon.
A pretty amazing combo....the 8x21 AWG fusion cable really takes the M5 up a notch. And paired with 1Z it’s really a sight to behold
Looks super neet, is the fusion a copper and silver hybrid? How did it change the sound? This looks like a DHC cable right?
Yep it’s copper and silver hybrid. It’s from Norne Audio, and I believe the geometry is different from DHC’s fusion. It adds more resolution and also weight to the sound, and yet the separation is also improved.
A perfect balance between detailed and full bodied sound.
Do you know how is norme different from dhc? Dhc probably has more purists approach
I don’t care much about cable/iem look-matching, but...PS Poetic+M5. Perfect combo
Haha, they sound good as wellI don’t care much about cable/iem look-matching, but...
well done, sir!
