Final Audio Design Impressions and Discussion Thread
HarryH2O
- May 26, 2015
Wish I was your friend!!! haha
She's a very, very special friend. On a whole 'nother level, if you know what I mean.
vwinter
- Oct 6, 2010
peareye
Wishing you all the best with that!
HarryH2O
- May 26, 2015
Thanks. Maybe I should just get her an Adagio III for Christmas as well, so that all bases are covered, lol.
cooperpwc
- Nov 20, 2006
Enjoy 7th base. That's extreme!
SearchOfSub
- Aug 28, 2013
why are people reporting Sonorous VI and Hope VI sound different? it seems like many are having hard time with trouble being harsh where with the HopeVI, people enjoyed it with no fatigue at all. Isn't it the exact product with different name?
ph0n6
- Jul 26, 2014
I have the sonorous now, and I have to say it matched the description of how the PH supposed to sound like with the A pad. I will wait for the B pad to see if the sound changes as dramatically as claim. After some EQ I really like it.
SearchOfSub
- Aug 28, 2013
Can anyone recommend a good tube amp $300.00 to pair?
vwinter
- Oct 6, 2010
Maybe a test run would be good on a tube amp due to the usual impedance curve on the BAs and the generally high output impedance on tube amps, it could affect the frequency response on the BAs. Or look for a low Z-Out tube amp.
Buddhahacker
I purchase the Sonorous IV sometime ago and it pairs very well with my Valhalla.
SearchOfSub
- Aug 28, 2013
Thanks for suggestion guys. Would it also be okay to use the sonorous vi with a set tube amp that recommends 33 ohm loads? just found a great deal on a set tube amp used..
ph0n6
- Jul 26, 2014
If you wnat tube sound the Aune T1 is an excellent choice as it use tube for buffer stage, you can pair other amps to handle to Low impedance.
SearchOfSub
- Aug 28, 2013
Can someone confirm if Pandora Hope IV and Sonorous IV is the exact same thing with just rebranded name? thanks appreciate it.
ph0n6
- Jul 26, 2014
Officially? Yes. Sonically? I don't know. What I can say is it sounds matches the various impression from this thread, and in a good way (type A pad with slight EQ).
