FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
post-15248721
Post #5,911 of 6,003
Darren Cotter
Thanks for the reply.
I haven't tried removing the cards, but the internal storage is visible in the X7ii's file browser and FiiO Music. The unit works perfectly apart from that one thing. It's not a big issue, as I don't use the internal storage, just the two 400gb cards, just wondered if it was an easy fix. The internal storage used to show up and I don't know when this problem started.
post-15248727
Post #5,912 of 6,003
Darren Cotter
I just went into file browser and found three old firmware files. I deleted them and it now works fine. Strange.
post-15259068
Post #5,913 of 6,003
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
12
Website
www.fiio.com
Ok, glad to hear about that. Thanks for the feedback.
Best regards
post-15262928
Post #5,914 of 6,003
Darren Cotter
Is it worth trading in an X7ii for either the M11 or the Pro, or would I be better off just getting an AM3D? I'm using FA7 and FH5's.
post-15263599
Post #5,915 of 6,003
salla45
@Darren Cotter
I have X7ii and M11, FH5 and FH7 and recently bought an AM5 module for the X7ii as I didn't quite like the sound of the X7ii with AM3 with the FH7's.
Firstly, I must say the difference between FH5 and FH7 is night and day, jaw dropping stuff. It's like the FH7 is what the FH5 should be and only by hearing them you realise what you've been missing :)
Now as to M11 vs X7ii, the sound boost by changing amp should not be sniffed at. I noticed a major improvement by moving to the AM5, and it elevates the X7ii to above the M11 imho. It's a different sound for sure; the M11 is laid back and mellow compared to the X7ii with AM5 which gives a very exciting, powerfully dynamic, visceral sound. Ref the AM3D, I think therefore it would be well worth a try given its pedigree. I'm tempted myself :)
Also, the M11 is a lovely machine for sure, but it's irksome not having the Google Play to be able to load apps like UAPP, which is quite sad for me. I am torn in daily use between the 2 players, lol. What a terrible choice! :) - To sum up... in retrospect, had I had the AM5 with the X7ii to start with, I'd probably not have gone for the M11.
post-15263644
Post #5,916 of 6,003
Darren Cotter
Thanks for the detailed reply. I have an AM5, but I am not using it at the moment. Maybe I should give it a try?
Also, the FH7 is on my to-do list.
post-15263651
Post #5,917 of 6,003
salla45
Yeah. Give it a dustoff. You might be pleasantly surprised. If you can audition the FH7, and really are keen to blow 500 squids, would recommend those over the M11 as an upgrade.
post-15263658
Post #5,918 of 6,003
Darren Cotter
I can't audition anything, as I live in Jersey, Channel Islands. I can just buy them from AdvancedMP3Players.co.uk and return them is they are not to my liking.
post-15263671
Post #5,919 of 6,003
dsrk
I would say skip the M11Pro, get the AM3D for now if you want THX flavor that's the only selling point of M11Pro. Wait for M15 or M15 Pro, that might be a worthy upgrade.
My friend who got both M11 and Pro told that there is hardly any difference between the two in sound quality. Pro sound little natural, has little bit extension at both sub bass and upper treble and noise level is low but it is not dead silent with his Andros.
post-15263673
Post #5,920 of 6,003
salla45
OK... If you like the FH5 then the FH7 are really similar in sig (imho) i lived with the FH5 for a year and now have lived with the FH7 for 3 months. I listen around 2-3hrs per day. A mix of classical, rock, jazz , country. The FH7 better the FH5 in clarity, separation, detail. They are constantly wowing me. The FH5, i liked a lot, but ALWAYS felt there was something a bit lacking, i always felt i wanted a bit more... the FH7 gives that in spaded. Need the right tips of course. But I simply moved my complys from the FH5's to the FH7.
Imho... go for it!! I'd be really interested to hear your views. The FH7's reduce me to tears regularly, which is what it's all about.
PS... I never get to audition stuff either. I buy from reviews and comments. Never really been unsatisfied with a purchase fortunately :)
post-15265641
Post #5,922 of 6,003
salla45
post-15265926
Post #5,923 of 6,003
Darren Cotter
I'm currently using FH5's and have FH7's on order. Should I stick with my AM3A, or use the AM5 that I have?
