FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
384 385 386 387 388 389 390 391 392 393
395 396 397
  1. dsrk
    I got another question. You pair RM1 to X7 II and start listening through your wired headphones, after a while RM1 goes into sleep mode right. If I want to change the volume or skip tracks, does it stay paired and work immediately?
  2. lafeuill
    It takes one push on any of the buttons to wake it up and then you get control.
    Beware though. I've given up shutting the RM1 down, or disabling the BT on the dap. The pairing / unpairing - once the link is broken - is problematic otherwise. Before I made up my mind to leave it on all the time, I often needed to tell the dap to forget the remote to be able to re-pair. Now that it's always on, no problem - even when restarting or shutting down the dap - provided I leave BT on.
    dsrk likes this.
  3. Peter68
    Thanks for the info. Guess it’s not worth the bother, then.
  4. dsrk
    Thanks for the information.
  5. dsrk
    They are asking me to send it again so that they will send it to China this time for repair, but I am not going to send. I can't live without my X7II that long. I am going to get RM1 as a workaround.
    Peter68 likes this.
  6. tjl5709
    What version did you download? What works with the X7 vII? I'm not sure what chip it has.
  7. LamerDeluxe (tm)
    I'm using the RM1 also. Really handy to keep in your pocket when your X7II is in an inside pocket or bag. I agree that re-pairing is a hassle when the pairing gets lost. The battery lasts pretty long.
    dsrk likes this.
  8. Heroes Killer
    I have the same problem with the volume wheel and I had to send it to China because I live in the Czech Republic but bought it on US Amazon when I was there.
    I also wouldn't send it just because of the volume wheel, there was another HW problem because of which I wasn't able to listen to the music.
    It's on the way to Fiio, I'll post here how they handle it.
    Meanwhile, I'm using my X3. <3
    dsrk likes this.
  9. LudoLVG
    In Neutron, go on Audio Hardware.
    CPU : it indicates ARMv7 + Neon (32 bit).
    So you should download the third apk from this page :
    http://neutronmp.com/downloads/category/2-google-play
    (ArmV7 + Neon)
  10. tjl5709
    Got it. Thanks. Seems to work. Time will tell. Thanks again for the reply.
  11. Halexx
    Anyone know how to solve this problem : Wi-fi disconnect after around 10 to 15 min while spotify is playing, it's like if the X7 Mk2 don't see that the connection is active and close it. I have this problem on different wi-fi connection (home, work). Thanks in advance!
  12. FiiO
    Dear friend,
    Please try to go into wifi settings, select the menu from the three dots icon at the top right, select advanced and set Keep Wifi on During Sleep to Always.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  13. Halexx
    Thanks! It works! This is a game changing point for my X7 usage, as i will able to use Spotify again.
    Now i hope Spotify will have find a way for songs to stop erasing on my device...it would be perfect.
  14. Darren Cotter
    When I plug the X7ii in for file transfer, the two cards become visible but never the internal storage. This is on two different laptops. Any ideas?
  15. FiiO
    Dear friend,
    If you remove the sd cards, Can the internal storage be readed?
    From file browser of the X7MKII, can you read the internal storage?
    Best regards
395 396 397
