FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
355 356 357 358 359 360 361 362 363 364
366 367 368 369 370 371 372 373 374 375
  1. FiiO
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    majo123, Fenriz and Fawzay like this.
  2. majo123
    Just had a quick scan of the updates and seems on paper fiio have responded very quickly with this... looking forward to updating when I get home.
  3. yenrios
    very good news, and from the release note good job :thumbsup:.
    i will try it ASAP
    I hope it's not the last update we will see and that the pace of release will be short:fingers_crossed:
  4. JukeBoxJimmy
    I don't post much but I was afraid my next post was about me buying an Ibasso DX200. I will hold off on that future post for now FiiO.
    .....................Jim
  5. russell finch
    Is the album art still the same size ?
    Also did you fix the issue where you couldn't swipe up to get the android navigation bar ?
  6. haoyuan
    The nav bar was never intended to appear with a swipe. It’s always invisible and you use the swipe gesture to active the button functions. If you want the nav bar, turn it on via settings.
  7. russell finch
    If it's invisible, how do I change between apps in android mode?
    Also if I turn it on in settings, it eats up screen space so when I use Neutron it makes the album art smaller. Can't stand small album art, don't see why it had to be so tiny on the new FW compared to the old one..
  8. haoyuan
    Swipe up from the left, mid, right bottom will yield different functions. It’s in the change logs and they even made images to demonstrate it.
    Alternatively, you can go to settings in Neutron and turn navigation bar off. It’s been there for as long as I have been using it.
  9. JaviAl
  10. majo123
    Ok just updated and definitely some improvement..... system seems a bit more smooth for a start especially when scrolling, also top left back/ directional arrow is also more responsive.
    Fixed volume limit back and working fine and was a greatly missed feature.
    Letter search at the side completely unresponsive now, it was working with songs but not with folders and now seems to be not working at all.
    Definitely a step in the right direction and I hope as more of us comment on the update and glitches if we come across any that fiio are as fast to respond as this update.....it's still not perfect and still a bit glitchy but good to see fiio trying to resolve.
    Edit ... letter search at the side just seems to be unresponsive when in folder mode and seems to be fine otherwise, flicking and using a bit more it definitely seems far better than previous.
  11. GR33dyblackie
    the latest 1.0.8 uldate screwed my X7 II. it played 1mins of a flac file and it hung.! rebooted it a few times, n issuee p
    ersist!
  12. FiiO
    Dear friend,
    Please do a factory restore after the updating and check again?
    Best regards
  13. ExpatinJapan
    FiiO X7ii / AM3B amp, Campfire Audio Solaris (with Symbio Peel W tips) and Dita OSLO cable (4.4mm).
    So far, so good. :)
  14. GR33dyblackie
    hi fiio sir thanks for reply. i was not hoping for a factory reset.
    i notice it have issue reading 256gb sd card. mine other 128gb sd card seem ok.
  15. Reboot
    Can't download from : http://fiio-file.fiio.net/FiiO_MusicX0131.apk. Is the server down?
    I intended to upgrade the Fiio app because when I try to play any file on hi-res (especially 24bit-96 khz or above) through the DLNA they are playing very slow, like a stuck vinyl.
