FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
352 353 354 355 356 357 358 359 360 361
363 364 365 366 367 368 369 370 371 372
  1. Darren Cotter
    Thanks.
  2. csglinux
    I'm finding issues too. It's disappointing that these software updates still don't seem to go through much in-house testing.
    I was enjoying the FiiO-link feature, but it seems to break after a while and won't re-connect until I wake the screen on the X7ii, which sort of defeats the purpose of having the remote-control capability.
    The FiiO music app runs great on my phone, both when connected to the X7ii and in stand-alone mode, but, @FiiO, please urgently consider the following...
    1) When I run the same app on the device it was presumably built for (the X7ii), it's almost impossible to scrub (search/scroll forward/backward) within a track, because 99.9% of the time the position button on the elapsed play bar just doesn't register input from the screen :frowning2:
    2) Your app really needs to implement the AudioTrack API on devices like the LG V30 and V40, because right now it re-samples all 44 kHz PCM to 48 kHz through Google's stupid Android mixer :frowning2:
  3. 3StarJ.R.
    THANK YOU! You got me to where I needed to go. I'm loving this X7, both the am3 and am5 amps are more than enough for my 600/650 300 ohm sennheisers and it's sound quality is the best I've ever owned in portables...
  4. dsrk
    Paul, if I use the line out to an AMP, it doesn't matter what AMP module I use (default or AMP5) it sounds same?
  5. Brooko Contributor
    If you’re using line-out, then you don’t even go through the amp module at all :)
    It uses the socket at the top.
  6. dsrk
    Thanks, I saw the circuit architecture and got confused.
  7. Darren Cotter
    It's the same version I'm already using. 1.0.8.
  8. Halexx
    There is an option to choose where to download in the Spotify app. Unfortunaly, in my experience, for some unknowned reasons, after some days it get back to the intern memory, causing problems. I got bored after many attempts trying to stop the app to do that and having to download the same music again and again, and canceled the Spotify subcription.
  9. 3StarJ.R.
    Good info, thanks to Bob Smith's instructions, I was able to get the downloads to my sd cards as I hoped. Now I'll be on the lookout to see if your problem with the spotify app hits me. Thank you for the heads up!
  10. Old Man Craig
    Is there a way to prevent the second microSD card from "going to sleep"? There is no end to the problems I've been having with my X7mkII and Neutron, Doubletwist and BlackPlayer. The second half of my collection has to be rescanned every time the X7 goes into a deep sleep.
    I chose those apps because they support sorting by "album artist." It looks like Neutron is the only one that supports 24/192 FLAC. I get errors on the other two.
    UPDATE - I discovered a workaround to the sleeping second microSD problem. I simply close the music app that I am using (either Neutron, Doubletwist or BlackPlayer) when I am finished using the X7mkII. If I wake up the X7mkII hours later by pressing the power button, wait a few seconds, and then open a music app, I am able to access the both the first and second SD card without any problems.
  11. FiiO
    Dear friend,
    No. It is not a same one in FW1.0.7.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  12. Darren Cotter
    The music player has the same version number, that's what threw me.
    Still the same issues with the EQ, though. Why can't you just work with Hiby to adapt their player to bypass whatever it is your player does? You did it with Dunu when you first entered the IEM market.
    Elric and Copland62 like this.
  13. Elric
    I still want to know why this was released without external playlist support.
  14. GR33dyblackie
    hi all does the X7 MK2 support DAC-out?
    does any1 use external DAC amp?
  15. Elric
    Plug the line out port into whatever external anp you want to use, after making certain the LO port is set to line out.
