FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
347 348 349 350 351 352 353 354 355 356
358 359 360 361 362 363 364 365 366 367
  1. FiiO
    Dear friends,
    The agreement of cooperation between FiiO and ViPER's Audio has expired, so we're afraid that the new version of FiiO Music will no longer have the embedded ViPER Effect plugin. However, we've been working hard on the dynamic EQ and will try our best to develop more audio effects.
    If you have purchased the ViPER Effects and would like to continue using it, you may download the apk file of the old version, copy it to the player, and then install it through ES File Explorer (this will overwrite the new version).
    Download link for the FiiO Music old version (apk): Click here
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. FiiO
    Dear friend,
    This version has
    fixed the sorting issue in folder,
    fixed the DLNA error
    fixed the EQ reset issue
    Best regards
  3. JaviAl
    @FiiO
    And what about m3u8 playlists and lossy and DSD gapless?
  4. russell finch
    Yes, loss of m3u8 is a deal breaker. I have uninstalled back to the old version until m3u8 works again. I only use fiio music for playlists, Neutron for everything else.
    I downloaded usb audio player pro which sounds excellent and supports m3u8, but it won't scan USB storage into the library, which is bizarre.
  5. Elric
    next bug, what happened to the volume limiter? ! always had mine capped at 40. my 6 yro was just messing with my X7 mk II and I put my iems in and got $#@!ing blasted at 120!!!!
  6. Brooko Contributor
    Let me get this right ......
    1. You left your 6 yo playing around with the X7ii
    2. Knowing your child had been playing with the X7ii, you plugged your IEMs in - and didn't check the volume?
    3. And this is FiiO's fault somehow .........
    stenog likes this.
  7. Elric
    Let me ask you if your wife demands that you drop what you are doing right _now_ and come to her, do you? because if you do, it is likely you set down what you are doing or have in your hands. :p
    I don't know if you have kids, but if you do then you know that you may not know something got messed with till after the fact. which invariably is followed up by with. "Did _you_ mess with this?" "yes...."
    Damn life happens a lot, especially with little boys... damn his sister who is now 21 wasn't quite a handful like this.
    Prior to this firmware, there was a volume limiter you could configure. now, there is not.
    So you tell me?
  8. stenog
    So you installed new firmware, plugged in your iems and pushed play. It never occurred to you to look at the screen? You still have a bar on the top that indicate volume level, battery indicator etc?
  9. Elric
    I installed the firmware a few days ago, and the volume was still where I needed it to be. If it's been working why would I look at my screen when sitting back down now? heck it wasn't even powered down yet
    Now, I know the limiter seems to be gone. Now, I know to look at the bar every time I pick it up and play.
    The things one learns after the fact still doesn't change the fact that what was there and working, isn't there now.
    stenog likes this.
  10. Brooko Contributor
    Yes - I have a 16 yo and 18 yo. And yes - if my wife calls I pay due attention. And yes I understand how inquisitive kids are. I guess I'm possibly old school - I always check volume before pushing play. And even when our kids were small, they knew what they could touch and what they couldn't.
    Interestingly, I never noticed a max volume limiter before. But I always check volume first - which is why I've probably never noticed it was there :wink:
  11. Elric
    I have relied on the volume limiter on the FiiO X5 and X5II after discovering that I could accidentally boost the volume fast with my player in a pocket. I only did that once, and that once was enough. :)
  12. Brooko Contributor
    I hear you - my biggest issue was plugging into the line-out. You only do that a couple of times and learn pretty quickly :0
  13. Elric
    I keep a little plug in the line out port to help not do that. You mentioned being old school enough to always check things, I do that with my stereo and my Schiit Stack. I really need to stay on top of doing that with my DAP as well.
  14. gazzington
    Oh I've done that before. Like you say, you soon learn!
  15. dsrk
    Hi All,
    The volume dial on my X7II is acting weird. Sometimes when I try to increase a step or two, it goes back a step or two. It's really annoying for me.
    I feel it's a hardware issue, I contacted FiiO India and they said it's normal. I never had this kind of issue with my X5III. I already tried factory reset but it didn't help.
    Is it really normal with X7II? or do I have to send it for repair?
