FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
345 346 347 348 349 350 351 352 353 354
356 357 358 359 360 361 362 363 364 365
  1. haoyuan
    http://fiio-file.fiio.net/Apps/FiiO_MusicX013003.apk
    New version of FiiO music app, this one improves sorting issue for those of you with out of order lists.
    Download, copy to device and run it from there. Otherwise you can open the link from the device itself so it’ll install.
  2. nlowran
    This DAP sounds like a lot of work to keep working
  3. Elric
    It's one of the best DAP's I have ever heard and used. it's just this current firmware and software build and the changes because of that.
    The hardware itself is amazing
    Sooner or later FiiO will get things right.
  4. harpo1
    I doubt it. The original X7 is still full of issues. FiiO makes some pretty decent hardware but their software has always been buggy.
  5. Elric
    Sadly I don't know if they will with the X7 mk II. :frowning2:
    I am still pissed at VIPER's Audio being pulled without letting the customer base know ahead of time.
  6. Elric
    Nope, sorting still doesn't work. m3u8 playlists are MIA, and any dir one is in is unreadable. the same goes for cue files
  7. rusnak666
    In this new version of FiiO APP internet radios in DLNA are finaly working!!! But! No VIPER's effects? No Way for me, rolling back :frowning2: It is a pity...
  8. Elric
    According to FiiO there won't be any VIPER's Audio going forward. Something about an "agreement of cooperation" having expired.
    It's something they seem to have failed to let anyone know was coming.
  9. dsrk
    Thanks for confirming. I have contacted FiiO India, sent them the video. They are looking into it, I think I need to send it for repair.
  10. Darren Cotter
    This is pathetic! FiiO even put the firmware out on here prior to official public release. They must have known it was buggy to do that. FiiO makes good hardware, but are crap at firmware.
    Anyway, if the rumours are to be believed, they aren't going to make hi-end DAPs anymore and are dropping the "X" rang in favour of the more consumer orientated "M" range.
  11. Elric
  12. Darren Cotter
    Here apparently. I've already asked for a translation when it was first posted, so if anyone can?
    I hope it proves to be wrong.
  13. Elric
    thank you. now if only I could read Chinese, simplified or otherwise.
  14. fonsecaj
    Agreed. When I got the X7II I also got an AK SR-15. I thought they both sounded very good, but the AK was definitely more stable on the software side. What put the Fiio over edge and why I kept it was the integrated Viper effects. I had known this was coming I would have sent the X7 back instead. Too late now..
  15. LamerDeluxe (tm)
    Yes, the volume wheel has about 1mm of play sideways. The volume going down instead of up might be contacts inside being dirty, that should go away after using the wheel a bit more (used to have this with my Creative Jukebox 3). It did seem like the volume changed by itself today when I was on my bike, that never happened before.
    dsrk likes this.
