FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
post-14739935
Post #5,221 of 6,044
haoyuan
Los Angeles
Los Angeles
I must be very blind to not see the obvious ??? :triportsad:
As I said my 1.0.7 named December 21 wouldn’t upgrade with an error, my X7 exhibits 1.0.6 as current version
So I downloaded the 1.0.7JP version from 15 December
Now it refuses to upgrade because says X7 has a newer version. This is not correct as it says its 1.0.6
Ok, no problem, re-flashed official FW 1.0.6 with the tool - ok
Upgraded to 1.0.7JP, fine, no problem, now it says it has 1.0.7JP
FiiO music app is absolutely equal !!! What the heck??? Where is the new app??? HEEELLLPPPPP, I am dumb :L3000:
Currently new app is only available via BETA
post-14739962
Post #5,222 of 6,044
Paulo Abreu
Madeira Island, Portugal
Thanks, I thought this was the beta version.
Is there a chance I can try that beta?
Regards
post-14739964
Post #5,223 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
This is what is changed in X7II-FW1.0.7 JP
  1. Added USB audio output function (standard output setting is DoP output.If your DAC does not support DoP input, change the setting from DoP output to D2P output with FiiO Music setting
  2. Added a setting to immediately switch to the playback screen when selecting and playing a song from the list (This option can be operated from the setting of FiiO Music.If enabled
  3. When ViPER Effect is enabled, when you play a specific FLAC file, the problem that the sound is interrupted has been corrected
  4. Fixed an issue where album cover art images included in certain WMA files might not be displayed
  5. Fixed a problem that the fast search bar might not be visible in the folder playback menu.
  6. Corrected a problem that audio may be distorted or audio may not be output when outputting DSD file via Bluetooth
  7. Fixed an issue where the setting function might stop when "setting> storage> NAND FLASH> total capacity> download"
  8. The data area was expanded from 1 GB to 4 GB * Partition change is effective only when performing the recovery operation with the following firmware update tool. For details of firmware update in recovery mode, please be sure to check FAQ . The player will not start up if it is misused . If you do not need to change partitions , there is no problem with the normal firmware update procedure .
  9. Japanese translation of FiiO Music app was added
post-14739975
Post #5,224 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
post-14739986
Post #5,225 of 6,044
Paulo Abreu
Is this what your looking for?
Maybe, that was the version I was trying to upgrade in the first instance.
Thanks for help guys
post-14740101
Post #5,226 of 6,044
Paulo Abreu
post-14740142
Post #5,227 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
post-14740263
Post #5,228 of 6,044
Paulo Abreu
What do you think of it as a longstanding user?
I still have to test for functionality and usability (I'm copying music back to internal memory,almost done)
post-14741085
Post #5,229 of 6,044
Paulo Abreu
The app looks fine, usability is more or less the same as the actual version, revamped with a new theme. USB audio output, replay gain, a native equalizer? Didn’t listen for music yet but hope sound quality is the same. Navigation by Artist or Album seems more responsive but it seems that some kind of cache mechanism generated a few app restartings ... but now seems more stable
For now, ok.
post-14741107
Post #5,230 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
For now, ok.
Yes that is what I found, I could not understand why it was more responsive after a couple of restarts.
Reactions: Paulo Abreu
post-14741131
Post #5,231 of 6,044
JaviAl
Madrid, SPAIN
Madrid, SPAIN
For now, ok.
My main problem with the new Beta is:
  • Not seeing any M3U or M3U8 playlist searching by folders.
  • Or seeing chinese characters on international characters like "Ñ, ñ, á, é, É, etc."
I basically use PlayLists in most cases (not in all) to play music. Because of this, is unuseable for me.
post-14741156
Post #5,232 of 6,044
Paulo Abreu
My perception was that in large lists the thumbnail generator was struggling to follow the scroll and app hanged
So I tried scrolling a few items at a time both on artists and albuns. After that seems more stable. And yes, now it renders the thumbnails almost instantly
post-14741164
Post #5,233 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
Yes all my Spanish and Islandic titles are back to Chinese. I think this beta may be not for the international market? Only one of my play lists works but I do not know why. I will go back to .7JP i think.
post-14741169
Post #5,234 of 6,044
peter1480
Edinburgh, Scotland
Edinburgh, Scotland
For now, ok.
Yes with very large numbers of files it is slow my art work is all 400 x 400 but it has fot better. But I think I will go back to .7JP. Once it failed to see my Samsung T3 and as JaviAl says some Chinese characters. Back to the music :)
post-14744646
Post #5,235 of 6,044
Halexx
Anybody else have problem keeping wifi connection active while using Spotify? X7 keep disconecting after 10 or 15 min and then i have to manualy reconnect it. Problem is at home and at work. Maybe there is a parameter set wrong?
