FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
321 322 323 324 325 326 327 328 329 330
332 333 334 335 336 337 338 339 340 341
  1. FiiO
    Dear friend,
    We have reported to the manager and the engineer about that. Will consider and assess about that first.
    If everything goes well, we will release a new firmware for the X7MKII this month.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    Vitor Valeri and Battlefier like this.
  2. snip3r77
    together with JP version?
  3. HaPeKa
    A bit off topic but has anyone an idea what's going on at FiiO?
    Until mid July they had several news per week on their homepage, since then it was really quiet ...
  4. russell finch
    Great - please fix gapless (it doesn't work on my playlists) and add replay gain.
  5. truenobzr
    I am new to X7 mkII, I have unknown battery drain issue for my machine. I only installed moov, kkbox, tidal and Onkyo HF player(becoz fiio player is not stable at all). Battery power will be lost over 10% around 5 hrs.
  6. Judge584
    Thank you for the update.
    Hopes it will include same changes included in Japan firmware that make it faster.
  7. JukeBoxJimmy
    YES, WE NEED replay gain. It is very useful while drive in auto and really great when on motorcycle.......................Jim
  8. rocksarkar
    can we use samsung gear 4 watch to control music and volume...
  9. snip3r77
    I thought these are basic stuff
  10. superbike999
    FiiO don't seem to think so. Some users have been asking for replay gain since the days of the FiiO X7 mark 1, but FiiO have just ignored them.
    I don't use it myself, nor do I wish to use it, but I can see that it would be useful for some users. Neutron which is available from Google Play Store
    does have replay gain.
    It is of interest to note that FiiO have not supplied any software/firmware updates since 30th May 2018, but their software "engineers" have never been their strong point.
    It was much better in the days of Joe Bloggs, who has recently left Hiby.
    lantian likes this.
  11. FiiO
    From the page you mentioned you could see:
    We have the new homepage: https://www.fiio.com/
    Best regards
  12. bootster
    I am interested in upgrading my X7 Mk II as it seems to be needing a reboot to work correctly just about any time I use it. It just needs to get a proper firmware update, as it hasn't worked correctly since I bought it. It sure sounds good, but it needs to be properly guided by a proper firmware update. I am really perplexed when I try to use it as a standalone DAC for my computer's audio system. It is almost like I am torturing myself every time I want to use it as a DAC to drive my computer's audio, while I am content to use my FIIO X5 Mk II as a reliable backup for a DAC. The X5 Mk II just plain works as a standalone DAC. The X7 Mk II simply doesn't, as reliably as the X5 Mk II anyway.
    I tried, and failed, to use the workaround to install the 1.07 firmware, so I just plan on waiting for the future, non-Beta release on this forum. Maybe there's a different 1.07 in the works that addresses bugs in the Japanese 1.07 version? How about just call it the 1.08 and be done with it?
  13. lantian
    Rooting and overclocking my x7 mk2 fixed most of the issues fiio's firmware has had for ever, no more random hangs, no more stop playing in the middle of the album and reset, no more playback issues so far. Have not had to kill/restart fiio music since.
  14. bootster
    I don't mean to sound short with you, but I don't have any idea of how to do anything you have described. It sounds like the device just needs some engineers to put out a proper firmware that fixes these issues. I don't really feel comfortable risking the device over something that should be taken care of by the developers who manufactured this device. I hope I can get this device to run before the holidays. :)
    majo123 likes this.
  15. snip3r77
    Actually you can toggle the performance mode?
