Dobrescu George
Reviewer: AudiophileHeaven
FiiO X7mkii and Final Audio IEMs
Mine works fine also no issues.Have you thought for a moment that it may not be the X7ii, but your particular Windows install? Could be a driver conflict. I just tried to replicate - and I can't either. Mine works perfectly.
Hey everyone, got my X7ii last week and have been absolutely loving it. Was wondering if anyone had suggestions for alternatives to Fiio Music? I don't hate the Fiio app but was wondering if anyone had better experiences elsewhere?
I apologize if this question has been asked already. This is a really long thread...
I have UAPP on my fiio x7-2 and it reads the second sd in my memory. Will check that this morning to confirm you.
I remember have difficulty to find it when I scan files the first Time but I find it sure
OK because for me it worked before.
Just try this :
- go to "scan the files" on the right upper corner when UAPP is on
- choose "manually"
- so just after you see folders, just click on the left arrow which are on the left down corner.
- then you should see "external sd1" and "external sd2"
- just tick the box and make the scan.
Hope it will work.
Me I have a little problem with UAPP. When I start it, it always put the pop-up android to authorize UAPP to access to the USB peripheral.
I think it because the Dac put in sleep when it is not in use
Dear friend,Hi, thank you all for testing.
I did more test, I have 2 PC:
Desktop PC : If I reboot my PC, then I have no sound until I unplug and replug my X7MKII.
Laptop : exactly same issue on my Dell XPS13 (model 9360)
I'm using Windows 10 v1803.
Dear friend,
We have reported the isse your met to our engineers and ask for more testing. Maybe you could try another usb ports and cables for help as well.
Best regards
I’ve looked at about 10 alternatives in the last 5 days.
Best two I’ve found are
Onkyo app
USB Audio player pro
The latter plays bit perfect music like the fiio app does. Also has Tidal integration right in the app. So you can add a tidal song to a queued playlist. Right now it doesn’t read the second SD card slot, but I emailed the developer and he said he’d add it in the next update. One caveat, it takes a long time to read the SD card. Took 30 mins to read my 400gb. But it just does that when you first insert it, or if you take it out and put it back.
Onkyo app is really clean & simple, much faster than the fiio. Onkyo doesn’t do bit perfect, but instead scales the music to android standard. Still better than the fiio app. Onkyo does read the second SD slot.
Keep in mind neither are cheap. Both around $10
