FiiO X7 Mk II 2GB RAM + 64GB ROM + ESS9028 PRO + Balanced + DSD + BT 4.1 aptX + Dual mSD + Dual Band WiFi + Opt Out
Discussion in 'Portable Source Gear' started by superuser1, Jul 6, 2017.
248 249 250 251 252 253 254 255 256 257
259 260 261 262 263 264 265 266 267 268
  1. 13-7
    Settings -> Audio Hardware -> Follow Source Frequency - that's pretty much it.
    Also, make sure to disable DSD, DSD over PCM (DoP) and also the Native DSD option "hidden" inside it (for now), as native DSD support for FiiO devices is still work in progress and, depending on the combination of settings, playback will either fall back to PCM conversion or there will be white noise.
    salla45 likes this.
  2. mrmoto050
    Nevermind
  3. mrmoto050
    nevermind
  4. Darren Cotter
    I don't understand the "Nevermind" thing.
  5. mrmoto050
    I was going to respond to your two threads, but decided to delete them and couldn't so I just changed to never rmind. Let's just leave it at that.
  6. roy_allan79
    Hello,
    Recent FW update fixed the stuttering issue when using viper eq. I'm real glad Fiio is taking feedback and complaints very seriously.
    Thanks Fiio for the amazing work!
    Dobrescu George likes this.
  7. Dobrescu George
    I didn't even notice that actually :darthsmile:
    Amazing work from FiiO, I really hope that the next 2-3 updates will fix all the things that are left, and then X7mkii will rule on the software asd much as it does on the hardware.
    roy_allan79 likes this.
  8. roy_allan79
    I definitely hope so. Then it would close to perfect.
    Hello George, hope you enjoy your Incubus even more with the new FW!
  9. Dobrescu George
    I really do!
    Incubus sounds so amazing on X7mkii and Amiron, and also on something like X7mkii and RE2000 :darthsmile:
    Hope you also keep rocking in there! :L3000:
    [​IMG]
  10. Darren Cotter
    I've just discovered the "Ignore" function. So I won't be able to benefit from your wisdom your anymore.
    Nevermind.
  11. Sonic-Debris
    Hey guys wanting a little help, I have the AK100II and thinking of an upgrade. I went into my local store today, and they let me listen to the AK70MKII and I didn't mind it at all, then I tried the Fiio X7II, which was what I initially went in to try out. I was using a pair of their Fiio F9 and was finding that there was a bit of a lack of bass? I did fiddle with the EQ but the sliders did not really change much. Could this be due to the IEM I was using? maybe the tips did not get a good seal? they were using balanced too, I did like the better volume compared to my 100II. Basically I am looking for a worthy upgrade. The UI of the AK was far nicer, but Fiio was way bigger like a phone, and I think was running old firmware, the Fiio EQ seemed to not do anything much
    I couldn't decide so I said I would do more research. I liked the overall size of the 70MKII, and the volume knob was better, as with the 100II I sometimes get it change in my pocket. The current phones I have are the RHA T20I and Momentum 2 over ears, I thought I would pick up the Fiio F9 or F9Pro while I was upgrading, any thoughts on this?
    To give you some more info, the AK100II was my first DAP, and I would often bump the bass up a bit too.
  12. FiiO
    Dear friend,
    For 1 and 3, we would report to the engineers and consider about that. The album images may not be visible from folder viewing.
    Small manual for FiiO Music: http://fiio.me/forum.php?mod=viewthread&tid=42219&extra=
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  13. markant
    Maybe you should add another type of playlist (by folders), in which to display the contents of the indexed folders (even if in a 1-level list) together with the pictures? After all, in the playlists you can show the images.
    It's strange, other programs can do it.
    Thanks for your reply
  14. Darren Cotter
    I think it has to be a fit/seal issue. The F9 had great bass.
  15. Dobrescu George
    There is a slider in the top right conrner, if I'm not mistaken, which you need to enable, so that the EQ works on X7mkii. Chances are, you were playing with the sliders, but the EQ itself was not engaged.
    As for the bass, I doubt X7mkii lacks bass :darthsmile:
