sjb57
- Dec 21, 2016
Just spent 4 weeks enjoying my X5iii and now returned to my X7ii. Even via AptX it sounds so 'clean' - Wow!
Hi All!
I SERIOUSLY need everyone's help.
Unfortunately I tapped the Device name multiple times and uninstalled Google Services, I tried to reinstall it but it won't work.
I even tried resetting the factory setting and even wiped the cache of the X7ii and when I did, the Device name changed to X7 only not X7ii.
Question:
* How can I re-activate/ re-enable google play and services?
* How can I revert back the X7ii original settings?
* I tried doing a Local Upgrade but it wont let me as is says" cannot install OTA as I do have the latest version".
Everyone's help is appreciated.
Thanks in Advance
Use the restore utility on windows to reflash and reinstall.Hi All!
Question:
Thanks in Advance
Hi!Welp...
FiiO mightr be able to provide a firmware package which you'd have to install. It should wipe your entire X7mkii... Why did you do this thought?
Hi!
I though by wiping and resetting everything would bring back the google play services but still, even if you install the google play and services 5.1.1, you cant still run the google servcies.
How and where can I find it?
Please instruct me in doing this
Thanks
I was more curious how you lost the google play services...
Reflashing the whole firmware should fix the issue.
So I was able to multi tap the device name and says " you have uninstalled google play services".
Settings > About Phone> Device name where the X7ii name appears, if you multi tap it it will permanently uninstall .
I tried downloading google play apk but when opening it it just says " Unable to open google play or services".
thats why I tried wiping out the cache and even doing factory reset multiple times.
How can I reflash it?
Thanks
I'm still searching how to reflash the firmware
@FiiO might be able to help
I know I did that at some point, but I can't find the exact tools to do it.
I guess you are looking for the Firmware Upgrade Tool?!
Welp...
