haoyuan
Chinese supports says new FW should arrive this week if nothing goes wrong.
if you read the previous comments, they said the update will be provided shortlyCannot find any update !
OK thanksif you read the previous comments, they said the update will be provided shortly
Yes! If everything goes well, the new firmware would be released this week.Chinese supports says new FW should arrive this week if nothing goes wrong.
Has anyone had problems connecting to a Macbook Pro running High Sierra in DAC mode?
I cannot for the life of me get it to work despite switching cables and ports. It is like the X7ii connects/disconnects/connects again but no output what so ever..
It is working flawlessly as a DAC when connected to my Windows PC..
Perhaps you could try using a different port or a different cable.
Also remember to setup the output rate correctly in Audio MIDI Setup.
You have to reflash the firmware using the windows toolI have disabled Google Play Services by tapping a few times on "Device name" under "About device" screen. The problem is can't enable the Play services again! Tried to reflash the firmware however is still disabled...
Any thoughts!?
Thank you for the reply. Like I said in my post, that was what I did at first with no success. Both cables I tried works with my windows pc.
I have set it to 44.1 24bit, like it says on the display of my X7, same result.
I have a late 2011 MBP 13" and as soon as I set the X7 as output device it starts to enable/disable, like a loop.
Should I try a factory reset?
