warrior1975
- Dec 5, 2013
New issue. Plug the power in when playing, my X7 shuts off. Anyone have this? Don't recall it happening on older FW.
I have gapless on too and I am pretty sure it is doing nothing.
Gapless play doesn't work after fw 2.0 update. What the…? Oh come on Fiio! Give us an update which fixes bugs, not adds ones. Honestly I don't understand why 2.0 firmware came out as it is so poor. I have more troubles with X7 now than I had before. Hope Fiio is aware of gapless play issue.
Hi.
Actually, we didn't make any changes on Gapless feature for latest firmware FW2.0.
The same files can be played seamlessly on the previous firmware FW1.8 or FW1.91? Could you please send some relevant files to us for testing? We just want to confirm the problem firstly. If you are convenient, you may provide the download link for files for me by the private message.
We will fix it by future update if the this issue indeed exists. So pls don't worry.
i respect FIIO as a company, and seriously if you can test maybe some cases or design your own case that can lower the RF interference it would be awesome
also please try to help us with google error message as what you posted as a solution is not working
Hi.
Hi, Sound Eq.
As for the Google service error message, you already tried the following steps?
1) Go to Settings->Apps then swipe left to the "All" list
2) Locate and click the "Google Play Store"
3) Click the "Force Stop" button then the "Clear data" button
4) Restart the X7
Or you also have tried to wipe the data & cache following the instructions from this link: click here, but it still can not help?
Looking forward to your feedback.
Hi, Sound Eq.
4) Restart the X7
Transducer size | 80 x 70mm |
Max power handling | 6W |
Sound pressure level | >120dB |
Frequency response | 10Hz – 50kHz |
THD | <1% full spectrum @ 100dB |
Impedance | 20 ohms |
Optimal power requirement | 500mW – 1W |
i have audeze sine and with x7+AM2 its loud enough, for me i play it at vol 90 high gain. and based on this spec, the audeze sine will run optimal with 500mW-1W output power. and the question is, do i have to switch to AM5?? has anyone tried with sine?? eventhough its portable on ear in fact its kinda hard to drive. due to the battery life im still considering getting the AM5
here's the spec of sine
[tr] [/tr]
Transducer size 80 x 70mm Max power handling 6W Sound pressure level >120dB Frequency response 10Hz – 50kHz THD <1% full spectrum @ 100dB Impedance 20 ohms Optimal power requirement 500mW – 1W
Dude, 90/120 on high gain with sine is insanely loud.
I have the Sine and AM5 and it sounds pretty optimal to me
