FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
post-12632624
Post #12,316 of 17,993
  Thanks Brooko. Maybe better off waiting to see if any third party amps become available if I'm OK as is?
If you're just running IEMs, the AM1 will give you longest battery life (about 1 hour advantage over AM2).  The AM2 is tonally slightly different - but if you volume match it with the AM1 the differences aren't as great as some would have you believe
Here's my take on it anyway : http://www.head-fi.org/products/fiio-am2-medium-power-amplifier-module-for-x7/reviews/15278
post-12632708
Post #12,317 of 17,993
gonzfi
Hi
Just ordered my X7. I'm using a FiiO X5ii with Fidue A83 IEM's at the moment (Impedance 11ohms and Sensetivity 104db). What module should I be looking to upgrade to, as my X7 will come with the AM1.
I'd also like a little in reserve in case I change to full size, but at the price, don't mind having various modules for various uses, if that is sonically the best way to go.
Thanks
Darren
Would love to hear your impressions on the x7 vs x5ii when you receive it Darren. I'm following your DAP trail by the looks of it having returned to an x5ii with mojo after selling my qp1r and now eyeing up the x7. Shame it only has one micro sd card slot....
post-12632772
Post #12,318 of 17,993
Darren Cotter
Irrespective of how the X7 sounds against the QP1R, that wheel. Really?!
post-12632889
Post #12,319 of 17,993
gonzfi
Dreadful. My second x5ii has a great wheel. Very accurate.
post-12632947
Post #12,320 of 17,993
Darren Cotter
Why Questyle couldn't reverse-engineer a X5ii's wheel and use it on their QP1R is beyond me.
Anyway, looking forward to the X7 and all things it offers by using Android.
post-12633335
Post #12,321 of 17,993
KC33
Fort Lauderdale
Fort Lauderdale
  Rats Bollocks! Two answers and two differing opinions. Who'd have thunked it. Thanks TJ Max for your answer.
He didn't like it but the vast majority praise the AM1. The only problem is that it's not powerful enough to drive hungry headphones. Your Fidue should sound great.
Reactions: Brooko
post-12633399
Post #12,322 of 17,993
sstyle
Somebody tried to compare with an iPhone 5S or higher?
post-12633528
Post #12,323 of 17,993
timetochill
The X7 has better layering/seperation, brings out a lot more detail, and tightens the bass. The X7 is superior is almost every way, unless you want more boomy bass.
post-12633593
Post #12,324 of 17,993
sstyle
I tried to hear that (with HD650 + desktop hi-end amp, also Weston UM3x, and Senn MX980). But can not. Used a FiiO HS2 for fast switching. Volume was exactly on same level on both devices (<0.1dB). Tried a special test disks from Marantz, OPUS, etc.
post-12634071
Post #12,326 of 17,993
ReizeiMako
iPhone 5S sound worse than Fiio X1 to my ears. The most different parts between X7 and 5S are layer and seperation.
post-12634231
Post #12,327 of 17,993
astrallite
"AM3  = >540mW(32Ω/1kHz)  >70mW(300Ω/1kHz) "  is the value for the balanced output. And the output power value for the normal 3.5mm output is ">190mW(32Ω/1kHz)  >25mW(300Ω/1kHz) "
The output current is actually related to the specification of the chips, which is different on the AM3 and AM5.
Hi, my understanding is the AM3 only has a TRRS output, is that correct? In that case does the AM3 module come with a XLR to TRRS adapter, or do we need to buy that separately? Thanks!
post-12634246
Post #12,328 of 17,993
x RELIC x
The West Coast, Canada
No, it has TRRS and 3.5mm TRS.
post-12634269
Post #12,330 of 17,993
x RELIC x
Sure, but I have a Sennheiser HD800S with a balanced cable XLR cable, so my question is does the AM3 come with a XLR to TRRS adapter, or do we need to buy an additional one?
Ah! Likely need to purchase the adaptor, but I'm not 100% sure on this.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
