FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
May 27, 2016 at 12:10 AM Post #12,061 of 18,019
don't worry about this
, all we need is time. give us 2 months and we will open the box
Nice, gonna be one heck of an update in that case lol
May 27, 2016 at 2:00 AM Post #12,064 of 18,019
@Brooko
Just out of curiosity, do you listen with the amp modules or do you connect the line out of the X7 to an external amp(/dac)?
Amp modules - mostly AM5 and AM2, but I'll also use AM1 if I know I'll be out with IEMs not requiring extra amplification. I don't usually use the line-out much at all - more if I'm testing other devices than anything.
May 27, 2016 at 2:09 AM Post #12,065 of 18,019
Great to hear, as I´m quiet satisfied myself with the amp modules. I almost started doubting myself when I´ve read that some guys think the amps are not good enough, and it would require a Mojo or RA 2.0 to get some decent sound from the X7.
May 27, 2016 at 3:01 AM Post #12,067 of 18,019
The am2 is an excellent amp module. Am5 seems great as well. I also own the Mojo, they are close in performance. Mojo is better, but the X7 is pretty damn good in it's own right.
Both the aforementioned modules are excellent and offer a differing flavour and drive. A draw of versatility became a major purchasing requirement.
Can you expound to why/how the mojo is considered better?
May 27, 2016 at 4:29 AM Post #12,069 of 18,019
I don't think you'll need Mojo if you already have X7. It will bypass Sabre desktop class DAC chip of X7, make X7 become expensive transporter, which could be replace by a cheaper mobile phone or better transporter (DP-X1 which have 2 SD Slots, newer Android and better hardware for example)
May 27, 2016 at 4:43 AM Post #12,070 of 18,019
I only have the AM1, but 99% of the time I have line out to RA 2.0 now. Just no going back to AM1 after getting used to how good the RA 2.0 sounds
But I have yet to hear the other modules so I am sure they will be great as well.
May 27, 2016 at 5:26 AM Post #12,071 of 18,019
am1 is low end hi-fi, it really impairs the X7.
get the am2, it's so much better sounding, clearer, spacious.
May 27, 2016 at 5:41 AM Post #12,072 of 18,019
Yes, with Fiio´s new strategy I think the AM1 might become superfluous, because the AM2 is so much better in all categories.
May 27, 2016 at 5:58 AM Post #12,073 of 18,019
Yeah, I guess with the AM2 the X7 probably performs on the same level as the RA 2.0.
May 27, 2016 at 7:28 AM Post #12,074 of 18,019
Tried and quite awhile ago as well - in both USB OTG as well as coax. If it is with AM1, I'll X7 is comparable but Mojo have some small advantage overall. But with AM2, I don't feel like X7 is anything less. In fact, I haven't really use Mojo much since I got AM2.
Just quoting an old post from ClieOS.
IMHO, Mojo isn't "better or worse" than the X7, just a different flavour.
