- Oct 14, 2013
With the X7 now being so wimpy, this perhaps forces me to order the ALO CDM
CDM is actually quiet good ! I looked into it for a while....but the price is a bit of an Ouch !
I said the exact same thing and everybody proceeded to yell at me for being "ungrateful."
It will be modular with an easily interchangable amp-module, and Fiio will be producing other amp-modules as well. Issue is, we'll have to buy them separately.
Give them time, they'll be on my ass soon, but yes 100Mw is sad. The Sony ZX2 gives us that already and with more storage (although I don't remember if it is expandable).
Um, doesn't the Sony ZX2 output 15mW per channel. It's output is incredibly weak.
Yes, you are correct and I will have egg all over my face (but I still won't delete my posts as I deserve the public thrashing for not checking my facts). I have actually been trying to find why I had the 100Mw feature in mind. Was that from the PHA3? If that is the case folks it simply means that you can learn from my mistake. Check your supposed facts before you post!! I had it in my mind that the ZX2 was 100Mw.
I think you must have been remembering something about the PHA-2 or the PHA-3.
Anyway, some folks are saying the low output power of the X7's stock/default amp is due to them wanting to make sure it does fine with sensitive IEM's. I call B.S. on that. Reason why is because the X3ii in my experience, and the X5ii by all accounts, have a PERFECTLY BLACK hiss-free background with sensitive IEM's, according to many folks even with super-low-impedance ultra-sensitive ones. They both have over twice teh power of the X7. Meanwhile, Fiio's own E12a is supposed to be their amp which is optimized for perfomance with IEM's (as opposed to the normal E12) and outputs up to 440mW if I remember correctly. So there's no real excuse for the "IEM Module" amp-module for the X7 being designed to only output 100mW at most. That is, unless you're of the fanboy-type who decides you love a company so unconditionally much that you'll make excuses for them rather than admitting when they have done something which is somewhat illogical.
I'm definitely not a "fanboy-type," but what strikes me as illogical is to lambast a product without having heard it first. This amp works quite well and the X7 sounds exponentially better than many DAPs I've heard. It compares well to Hifiman's flagship and I look forward to more amp modules. They even included a screwdriver... a tool, not the cocktail.
The X7 is offering a very different experience than previous FiiO players, now including WiFi, a touchscreen and the Android OS with the ability to add apps. It's a new deal, not the next generation of an existing product... so it should be judged by its own nascent and evolving standards.
This is not a replacement for the X1, X3 II, X5 I & II... but an ambitious and very successful new edition to their line.
