FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Aug 15, 2017 at 9:51 AM Post #17,491 of 18,019
I will notice that FiiO Music app, with the new themes, is more slowly and less responsive than the old blue theme.
Aug 22, 2017 at 3:00 PM Post #17,492 of 18,019
I've been claiming this for years. An option to mark a song to be the next to play when finish the actual song and then continues the order next to the marked song if no more songs are marked or queued to play. Like iRiver H-1xx or H-3xx models.
I'm also reclaiming:
  1. DSD256 Support
  2. Allow Fast Forward/Rewind by long pressing next song key.
  3. Allow to skip to next song in the next album or folder by pressing or long pressing or two pressing a key.
  4. Allow lyrics from TAGS: LYRICS and UNSYNCKED_LYRICS.
  5. More use of ID3 TAGS: Disc Number, Composer, Year, Ratings.
  6. Allow library to search, order and select by composer, year, ratings.
  7. Allow Fonts size selection for Fiio Music App. Some people has eye visibility problems.
  8. Allow landscape mode. Like other Android players.
P.D. Many other features that I have been claiming in the past, have already been implemented by FiiO.
Yeah, and playlist integration. The playlists created externally would be nice if it can be shown in playlist tab, not through folder browser. Those playlist and lyrics thing that keep me from using fiio music app, still using jetaudio plus and rocket player since day one. What about it @FiiO ??
Aug 24, 2017 at 4:00 PM Post #17,495 of 18,019
Aug 25, 2017 at 2:08 PM Post #17,497 of 18,019
Why the battery indicator messed up?? It says 48% then it turned off
I also noticed.
Battery info is definitely messed up.
It was 30% when I turned off yesterday, now 96% w/o charging... (unless X7 found a way to charge itself)
Aug 25, 2017 at 2:39 PM Post #17,498 of 18,019
Maybe X7 resets battery to 100% after powering off, right now it's 80% and "approx. 2hrs left". It doesn't sound right to me. BTW I'm using AM2A with JHA angie. I usually get about 6-7 hours from 100% charged.
Aug 25, 2017 at 2:44 PM Post #17,499 of 18,019
I also noticed.
I'll chime in as well - had a similar experience after installing latest FW3.3.1.
I was running my battery down after the new install and observing pretty typical usage/battery drain - started above 90% and played for about 5/6 hours before the player randomly shut off somewhere in the 10-20% range but when I rebooted it says it has 87% charge...
Aug 25, 2017 at 4:09 PM Post #17,500 of 18,019
I restarted X7 again. Battery went from 60% to 97% w/o charging. Battery info is definitely broken. Please confirm @FiiO
Aug 26, 2017 at 2:20 AM Post #17,502 of 18,019
1) the new theme is slower than others.
2) Battery went down to 60%, but after turning device off and on, it shows 90%.
Fiio, we are waiting for the fix)
P.s: Fiio X7 is probably the most supported device ever. So much attention to it, firmware and real dialogue with real users! Keep going Fiio!
Aug 26, 2017 at 3:06 PM Post #17,503 of 18,019
- This firmware show incorrect battery info. Resets to 100% (when is 10%) the batery indicator every time you turn on.
- No album art on the main screen in Fiio Music (the first screen when you start FiiO Music).
- Scanning Library takes about 3 to 5 minutes to begin scanning.
This bugs and errors not occurs in previous firmware versions.
