muzikT
- May 7, 2014
Hi,
I have a very strange issue. When my X5-3 is connected to my home stereo (via digital coax), I am unable to play audio and charge the device at the same time. I have tested connecting and disconnecting the USB cable while audio is playing. Disconnect = audio playing. Connect = audio stops playing. In fact, even just touching the connectors (USB to charging port), without fully connecting the USB charging cable will cause audio to cut out.
What gives? Am I not supposed to be able to listen and charge at the same time??
