Fiio X5 - Custom/Modded firmwares
Apr 20, 2015 at 4:01 PM Post #2,057 of 2,613
x RELIC x
The West Coast, Canada
I got this bug, i do not know if it is present for anybody else, or if it was there before the latest firmware:
So i go to folder browsing, and i enter a folder.
The last item in the list,
for example card1/linkinpark/meteora, i am in this folder, if i browse the files within, the last one does not have top and bottom white line, it has only top, like the bottom last line of screen was cut. Anyone can tell me if this also happens to them, or if i can debug it?
[i am using my own theme, and i am also wondering if this happens on the original, you do not see both under and over the text red lines]
That's the default behaviour.
My suggestion would be to reduce the vertical size of the highlight bar by a pixel or two, but then you may need to reposition the lines in the background image(if using any) if they don't line up. Best thing to do is to try it and see what happens.
Apr 20, 2015 at 4:02 PM Post #2,058 of 2,613
x RELIC x
Thanks for the comments guys!! :beerchug:
Apr 20, 2015 at 4:14 PM Post #2,059 of 2,613
AndrewH13
CanJam London 2017 Ping Pong Champion
Southend, England
  H_U_D_ is up!!!!
Two versions, one that covers up all album art (HUD_Primary) and one that leaves the album art as is (HUD_AlbumArt).
Great Relic, even down to the Updating Media animations. We are all spoilt for choice, but this goes into my top four, all on rotation.
Only theme that could break into my choices now be Girl Girls Girls (Motley Crue album) as alluded to above :wink:
Apr 20, 2015 at 4:29 PM Post #2,060 of 2,613
Dobrescu George
Reviewer: AudiophileHeaven
Bucharest, Romania
thanks a lot!
this helps me develop the theme much faster.
I kind of preffer it this way, if this is how it should be by default, it does not bother me.
I have very faint background lines, so it does not matter if they are offset'ed.
Your theme is a real piece of work, it has a "many hours of work" written all over.
I will try to upgrade mine themes on the same basic principle, i would never try to do something so conspicious,
but someone who wants to do it, can try to do a theme for their own. it can be learnt fast, very fast, in a matter of hours, and it is free.
in fact, i started building something because everything that already was, needed some adjustments to work how i wanted.
Apr 21, 2015 at 1:39 AM Post #2,061 of 2,613
Hawaii/Japan/Your Head
I don't even know what an X5 is but this Theme changed my life!!​
-Peter Travers​
Tell HBB I don't hit click till I see the money transfer..
Don't type that part of course
The Launcher.
Relic..I'll mention him off the bat to discuss signatures.  Relic is like a guy with ornate doors all fitted out so you know before you enter it's gonna be nice.  The grand staircase or the Grand Piano on a slightly raised stage just inside  will not surprise you. You knew coming in it was going to be good.
Everything is perfect. His paintings are bubble balanced. You could take out a level and check but he already did. He imagined you'd check cuz he would.
I do.
I check everything that hangs on my wall with a bubble balance. I got like 5 laying around. If I go into a restaurant or anyplace and they have a painting off balance I leave.
No ****.
I walk out the ******* door. Did it 2 weeks a go. My chick hates it but if the staff didn't notice or didn't care... those are 2 good enough reasons to keep my cash in my pocket.
My stuff is lined up all around and it is checked for balance (Japan has lots of mini earthquakes).
My launcher was forced by a top bar to be balanced...all at the same height....no f'ing way!!. I took care of that in my last two of the  "Hi" series by making it seem to be kinda not really there. I would not line up 2 hangings on a wall at an identical height. They would be perfectly balanced Hor/Ver themselves but would be askew relative to one another.
My launcher is not just an exercise in different it's an exercise in gaining comfort with my own device.
This launcher does that. I got my full screen images and the user gets the preview left and right but it doesn't take over the spot being focused on. I could make the current selection a solid but that destroys the point of all the other transparency. It would jump out at you. I don't want it to.
It rotates in the wheel direction and is aesthetically pleasing to my O.C.D eyes
Underneath
There are 2 times when the same image or bg will be seen  My music and Categories and the category sub screens. There are a lot of times so this jumped out at me in full size. It's an amazing image. Give this to a University art class with 30 students and ask for an intro, the image is the body and an outro...you'll get 30 different stories. It's ...I got lucky.
The folders are now dark and the highlight is a slate fade. Matches the theme and gives enough contrast.
Fast Picking
 This needs to be the highest contrast for me as I am in a song and looking for a nearby song. An image or photo is going to be a distraction but this spinning album into a rainbow was perfect. Faded with a highlight that simulates the old Nakamichi decks with dark red/orange plastic covering white lights making them orange. Love it.
EQ
I am an EQ fanatic. Comes from my Car audio experience where it isn't even an option. You HAVE to use one.
I was looking for another thing when the thing was staring me in the face.....A freq graph *facepalm*
A DAP with no eq is not flat it's your gears factory tuned curve. Everything done by eq is relative to the cans/IEM response curve not the 0dB. This will be the default for now going forward but will be made more accurate and matching. Forgive the infancy of it and look forward to the development of it. Once you get your brain on it you cannot go back. I kinda NEED this. I changed some presets just by calculating the things wrong with existing ones. It is functionally better. For me. I think folks who look at graphs a lot will like this a lot once it is polished.
No Album art
  As soon as I saw this...I thought it looked like my chick.
Same hair,body...hips are identical.
/img/vimeo_logo.png
I'm a hips guy. I spent a while moving her enough to the left to keep that back in view. I just loaded music...it has no art and not a **** was given. It's totally matching the theme. Progress bar is red with a blue musical note at the tip.
This is version 1.0
Feedback is usually asked for and Romani helped me get to here by noting some stuff I missed but I made this in this way and aside from the no album art it's gonna stay this way unless I choose otherwise. I doubt it. Just polishing maybe.
Video stops abruptly because the camera battery died. So that is the video it gets. It looks better in hand anyway.
Link to fw     https://app.box.com/s/z5lveiu5di38s6iacyv9ow41ywqp09fj
Apr 21, 2015 at 2:53 AM Post #2,062 of 2,613
x RELIC x
EPIC!!! LOL!!!
So is it done HBB?
Apr 21, 2015 at 3:05 AM Post #2,063 of 2,613
  EPIC!!! LOL!!!
So is it done HBB?
 Some hoodlums vandalized a H_U_D ad in Chicago (it's being investigated...I'm in Japan...my hands are clean..I have no idea)
Yes V1.0 is done. I may have to offer an alternate no album art version.
The EQ is awesome. It took my mind a bit to get used to it but either your term relevant was ahead of my mind curve or I found it's value. Cans of course are not trimmed zero. Even LCD and such have late spikes and dips and when EQ'ing it can be easy to forget that zero on the DAP is not zero for the cans. Every time I look at the eq I am aware of that and I changed some pre-sets and it makes sense. It will be improved upon and some tweaks but just a few.
I did a vid but the camera battery died and I spent most of my time on a girls ass.
Apr 21, 2015 at 4:02 AM Post #2,064 of 2,613
x RELIC x
 Some hoodlums vandalized a H_U_D ad in Chicago (it's being investigated...I'm in Japan...my hands are clean..I have no idea):D
I did a vid but the camera battery died and I spent most of my time on a girls ass.:frowning2:
:blink:
I think I may be a bit thick here........ What are you talking about??? Hahahaha..........
I was refering to your adds for your new theme, I love it! Brilliant way to present a theme!
As for the EQ I can't wait to see what it looks like. If you kept the logarithmic frequency scale it is completely relevant!! Did you change the scale numbers to a more frequency chart like scale, something like 90db as a center point instead of zero? That would be cool.
Can't wait to try it!
Edit: Duh, I get it!! Stupid tired me........ Hahahahaha
Apr 21, 2015 at 9:21 AM Post #2,066 of 2,613
Romani
-Peter Travers​
The Launcher.
I do.
No ****.
Underneath
Fast Picking
EQ
No Album art
This is version 1.0
This one is well executed. Thanks for reaching out for some of my feedback.
Apr 21, 2015 at 6:20 PM Post #2,068 of 2,613
x RELIC x
Glad to see more people exploring the separate EQ bg! Opens up a lot of ideas. :)
Nice Carel.
Apr 21, 2015 at 11:38 PM Post #2,069 of 2,613
x RELIC x
Innerfidelity has a DAP comparison article where they give a shout out to this thread in the X5 section.
Nice!! :D
Article LINK
