TjPhysicist
again, i'm not sure exactly what you did, but they are available for phones that ALREADY HAVE working services that need update to those APKs. Like I said, there are some hardwares out there that do NOT have permission to install google services (this is actually a license you have to get) and if you install play.apk on those you have google play but it WON'T work. You also have to install and get working the programs and background things that deal with talking to the google servers etc. It's a little odd to me that you were able to uninstall play services - this may be a bug with how Fiio makes the ROM, on phones you wouldn't be able to do that, in fact you wouldn't be able to do that on most every ROM i've seen out there.Yeah, i always had this feeling that android is just a crap gui for some lightweight unix kernel or something, now i know it.
I wouldn't just yet try to rewrite rom as fiio chose to use us as beta testers and customized the android so that nothing will work if we change something so deep in the system. Or at list sound might be affected. Anyway, then if the services are not just apk, why are they available as apk downloads?
But getting a bit more philosophical: i think this was talked about a few pages back, the biggest issue with "audio player that can do Tidal and Spotify including offline" is that pretty much the ONLY way to do this is to have either android or iOS (tidal for e.g. has a legal restriction that lets offline only be used on iOS or android apps). Android Audio, is meant for regular people. It's not hte best, but the sort of thing that is their priority on getting right makes sense for someone like my mom: Bluetooth audio, working audio, multiple apps being able to play sound, music while screen off and some apps able to take priority (e.g. i may wanna hear a call come in even if i'm listening to music). Unfortunately, bit perfect audio is NOT one of those features and for whatever reason google's audio implementation is REALLY BAD in these respects (my personal bias against HAL and ALSA mean that I blame the fact that Android uses them, for the badness). So, fiio's job, although seemingly easier than constructing an OS from scratch like say AK or Sony have done, is to build a working audio subsystem for android - if you've ever tried to work/code with OTHER people's software it can often be HARDER than coding from scratch because now you have all these lines you have to color within. Frankly, it's great that Fiio has done such a good job of the audio subsystem, unfortunately they don't seem to be as good as say apple at UI programming or squishing bugs...so there's that.
Honestly, I really wish google THEMSELVES would put out an audio player, or maybe apple: heck apple could bring back the ipod, the way sony bbrought back the walkman (well, maybe not "back", but walkmans are STILL a thing, unlike ipod, but now only $1000+ audiophile devices) - now with iOS and crazy expensive DAC/Amp for audiophiles. Hell, they could charge $3000 for it and i'm 100% certain this entire forum would go CRAZY over it, myself included.
