- Jan 30, 2011
There will be a large impedance difference between headphone out and line-out. This can cause frequency changes.
And per an earlier suggestion, I DL'd the trial version of BubbleUPnP and it seemed to work okay. I purchased the license, now it won't recognize my 2nd micro SD card, and won't let me change the Renderer.
Is not Nuetron displayed as Renderer?and won't let me change the Renderer.
Dear friend,My x5iii keeps crashing repeatedly when I on fiio music. Probably have to do it few times then it stop crashing everytime I want to indulge in music. Anything I can do?
Nope...I can get DSD64 and 192 just fine on coax out.![]()
I've seen similar odd things with the screen on/off, sometimes when I power the X5 up it'll stop after one track, turn the screen on and it continues and will go to the next track as long as the screen is on. As soon as the screen goes off it would stop again at the end of the current track.Hi @FiiO
Yesterday I found a bug in firmware version 1.1.7 (not the beta version), when DAP is bellow 15% (without power saver, no idle timeouts) on balanced mode, music stop playing when screen shuts down resuming automatically on screen boot;
Its is not usual to have DAP without any charge but nevertheless is it a really annoying bug, this did not occurred on non balanced output (since only start using balanced yesterday after receiving the F9)
Thanks
Though this is unrelated to the power level but I am listening via the balanced output. Rebooting the X5 or playing about with the on screen controls for a bit usually sorts it.
Is a pita when it's in my bag/pocket.
Probably interchangeable with other brands.@FiiO
Will you please sell the SD Card Trays as spare parts.
I cannot connect my X5III to my computer so I have to frequently remove the SD Cards if I want to add new music and I am concerned that the trays may get lost. Without the trays the X5III is worthless so please offer them as spare parts.
