Sound Eq
- Nov 9, 2013
No, I'm using this busybox packages on both players.
so i assume i flash busy box first
also did u set v4a in compatible mode or normal mode
I using v4a on my DP-X1 in normal mode.
I have not tried to install it on X5 yet.
So, I finally got around to trying to use the X5iii as a DAC and was playing with some items in Audacity... then realized. Every track had a 4 second silence before the music actually started. I seriously hope this is being addressed in the next firmware update.
I'm not experiencing this, and never have. I haven't tried listening from Audacity -- using FooBar.
I had been using 1.1.4 with no problem as USB DAC, then switched to WindowsX's ROM -- still no silence, still using FooBar.
I'll give Audacity a shot tonight and see if it's app-specific.
Don't worry about it. Thanks for testing though. I realized it is because I have 4 drivers loaded for DACs on my Win10 Tablet, and it was what I was doing. I restarted and it is working fine now.
@Hawaiibadboy It's okay. I'm sorry too if my opinion I state ain't clear enough.
@Sound Eq I think pairing is one important factor. X7 with different amp module can sound fuller and have great musicality.
Hope next gen of X7 will be the best DAP we've ever met
Here we go:
You can download TWRP (custom recovery) for FiiO X5-III here.
SuperSU package (root) for installing through TWRP is here.
Brief instructions:
- Unzip twrp-2.8.5.0-X5.zip, install drivers (run DriverInstall.exe);
- Power off the X5, connect it to the computer via USB while holding the Previous track button.
- Start AndroidTool.exe, make sure that only checkbox #2 is checked and LOADER device is found;
(for flashing stock recovery just untick #2 checkbox and choose #3 - recovery_stock.img).
- Press button, wait till flash operation is completed;
- Go to Advanced function tab and click button.
- We're done.
To enter custom recovery:
- Power off the X5;
- Push Previous track button, Play/Pause Button and Power button simultaneously.
- Wait 5 sec, release Power button;
- Wait till logo appears and then release all buttons.
The guide about using TWRP is here.
Enjoy!
If you appreciate my work, you can donate at the website in my sig...
Thank you.
Because of my tight budget I have to take a viable decision.I will first go to a near store and compare v20 with my first gen x5(cannot try x5 3rd only available online).if they both sound same quality I will go for 3rd gen and if I find any improvements on v20,I will buy v20.thanks for the help bro.
Hey guys just got my FiioX5iii.... I see many pages behind that Fiio wrote charging specs... But can't find it right now. Can someone please write it down to me? BTW i just have 5v 1A (smartphone) charger here, will it do??
LG V20 is close in sound quality but can not reach the level of X5 3. So close yet so far.
It's more laid back sound, I see you have ATH MSR7 and they pair great with LG V20.
Ok Thanks!!
