This is for Fiio Tech Support: I think I have pretty much confirmed that the X5 III does not like Windows VBR WMA (using the Windows 10 codecs) files with embedded album art. I randomly sees some and not others. I went through and put a nice sampling of cuts and albums which I reconverted and re-embedded the art. dbPowerAmp sees it, Media Monkey sees it, Sonos sees it, Squeezebox Touch sees it, as does VLC and Windows Media Player on my laptop.
Just tried the same thing with APE files - same result.
FLAC files work fine and show all art.
Just converted the FLAC files to MP3's (Yuck) - they all show album art fine.
All conversions in all above tests were done using dbPoweramp version 16 (latest version) using their codecs from their website.
Going to try the same procedure tonight with different conversion utility.
Another follow-up for
Fiio Tech Support: Just to make sure it was not the conversion software I was using, tried all of the same procedures with a completely different utility. Exact same results.
The only files which correctly display album art are FLAC and MP3's. Ape, WMA 9.2, WMA 10, CBR, VBR - none show album art consistantly. Some files do, some don't - even though they were all created with the same utility in the very same way with the exact same jpg files for album art.
When I try to use the loaded SD cards which came out of my X5 1st Generation - inconsistant album art. They all showed the correct album art on my X5i - not on the Gen III.
I find this very disappointing. Hopefully someone at Fiio can find a solution.
