trgz
- May 31, 2013
Yeah don't worry about that. Happened a couple of times to me as well. Quite scary until the device cools down and does the magical resurrection trick.
In summary, the RK3188 does not have a temperature sensor (appalling I know) so FiiO wisely put in a few temperature regulators on the board. When the board temp reaches a cutoff temperature the power to the board is just cut off, but if the charger is still connected the device will remain hot. If this happens to anyone, unplug and leave it for 6h (or pop it in the fridge) and the device will boot either to bootloader or normally to Android.
The black part of the picture is where the RK3188 CPU is, obviously it goes back to normal after a bit.
I've just discovered this post in this thread and it's the same fault that I'd noticed twice before whilst trying out two earlier kernel versions (here's the first time I encountered it https://www.head-fi.org/threads/fii...rs-and-much-more.906004/page-13#post-15125409). TBH I'd rather not push my player beyond what I would deem as 'safe' operating parameters.
Questions:
1. Is this custom kernel specific or has it been observed in the stock too? I will probably revert back to stock again if it's the custom kernel (even though I've spent a few days converting my 2 SDs to exFat and re-installing the custom kernel)
2. How many users have seen this?
3. Has it been observed during simple playback, or standby, or scanning for media? Personanly, I suspect that mine was scanning on both occasions. nb I used a smart suppy the first time it happend (advised as safe by FiiO) but a standard supply the second time.
4. Is there any app (preferably free) that can detect a dangerous rise in temp and reliably shut down the FiiO before the screen starts to cook, ie before the cutoff that doesn't actually work if powered up (ie when sat in the DK1, or even the K5)?
BTW the general advice is to not put a hot device in the fridge or freezer
Thanks in advance
