Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Discussion in 'Portable Source Gear' started by xloud, Dec 8, 2016.
1008 1009 1010 1011 1012 1013 1014 1015 1016 1017
  1. Preachy1
    Yes, a radio static like effect was what I was getting. I'm just going to turn it off for now. But thanks very much for your help!!!
    TiborG likes this.
  2. WitzyZed
    Now gone is the static that had been introduced w/ Neutron’s “All-to-DSD(64)” setting.
    http://neutronmp.com/feature_all-to-dsd.
    As of 2.12.3 that’s fixed :)
    http://neutronmp.com/downloads just install ARMv7 + Neon version on top of your existing version and you'll be good to go!
    Hasn't cooked my player just yet, but if it does I'll report on any new elements I discover :atom:
    stillman and jkbuha like this.
  3. Thx1326
    I've been looking at the M11 and trying to decide if I should make the change??? But in the meantime, my X5 III has been working fine with all stock software and firmware. However, my curiosity has the best of me and I am now wanting to make some upgrades to my X5. Can someone tell me what pieces of the puzzle I will need to do the following and is there a single place to find all of them? I've never rooted an Android device before - so any help would be much appreciated.
    1. This is a stock x5 III - need all necessary software and instructions.
    2. I want to keep the Fiio Music player so I can keep it in Pure Music Mode and use the Viper effects. What is the latest version of Fiio Music Player should I use?
    3. I only want to enhance the performance, speed, etc of the X5 - what is the appropriate software / Firmware?
    Thanks in advance.
  4. MinnieOne
    https://kernelmods.com
  5. WitzyZed
    I've PM'd you instructions several weeks ago, and the kernelmods site is going to link to a thread that's linked in my signature. All links are there. >_>
    It can be easy to get lost in the weeds here, there's more instructions here https://4pda.ru/forum/index.php?showtopic=825351&st=1620#entry73841818 too (w/ google translate)
