FiiO X5 2nd gen Impressions and Discussion thread
Jul 19, 2016 at 8:32 PM Post #5,461 of 7,088
I'm currently trying to decide whether to purchase the X5, X3 or the Lootoo Paw 5000. My primary concern is capacity. I'd like to make as much of my collection as portable as possible. I know right now that the highest capacity microSD available is the SanDisk 200GB, I also read the X5 has some problems with regards to OTG compatibility.
I've read that while the X5 can house two high capacity microSD's, it tends to lock up if a large USB stick is attached via OTG while the X3 only supports 128gig single card it can run much larger storage devices through an OTG cable. Out of the two which is the most favourable for capacity?
I guess the Lootoo can apparently support up to 2tb, even though a card hasn't been made to that capacity, I'm concerned that that particular device has issues with regards to sound quality and a less than user friendly interface.
Does anyone have a high capacity rig with the any of the above devices, and has the X5's issues with OTG been resolved?
Jul 19, 2016 at 8:36 PM Post #5,462 of 7,088
Get X5ii + 2x200gb microsd cards.
OTG is sketchy on all DAPs right now, and X5ii support for OTG is dropped to avoid problems.
400gb of music on microsd cards. I can barely fill 2x64 nowdays, because I don't listen to everything while out and about.
Jul 20, 2016 at 6:28 AM Post #5,463 of 7,088
I've turned this over to the main forum as I needed a single post to have thread starting rights.
Very dissapointed that they have abandoned OTG support altogether. While 400gb is a great capacity it wouldn't be enough to get my whole music collection onto one device without having to switch out SD cards. I'm willing to make compromises obviously, but I'm really looking for something that can house 500+gb at a minimum.
Any idea if it could handle the new Samsung 256gb micro SD?
https://news.samsung.com/global/samsung-electronics-introduces-the-evo-plus-256gb-microsd-card-with-the-highest-capacity-in-its-class
Jul 20, 2016 at 8:55 AM Post #5,464 of 7,088
Hi,
Has anyone used Bowers and Wilkins P7s with the Fiio X5 Gen 2?
I noticed the player has an output power of 245mW @32 Ohms, the P7 headphones have a maximum input of 55mW @22 Ohms.
@22 Ohms, the Fiio X5 would be pushing out over 300mW.
Could I easily blow the P7 headphones?  If anyone has the P7's with the X5II, are they a good match? How high is it safe to go with the volume level on High Gain/Low Gain?
Thanks,
Shannon
Jul 20, 2016 at 9:56 AM Post #5,465 of 7,088
  Hi,
Thanks,
Shannon
Maybe I'm wrong, but 55mW seems incredibly low.
Jul 20, 2016 at 2:57 PM Post #5,467 of 7,088
I misread, even worst, it says 50mW Max. Input power on B&W's website. Headphones are 22 ohm.
It'll be fine. If you listen at levels that will damage the headphones then you will certainly damage your hearing. Many people are using the X5ii with more sensitive IEMs without issue. Use common sense and don't turn up the volume to max, or plug in headphones to the line-out port.
Jul 22, 2016 at 1:08 PM Post #5,468 of 7,088
can we expect any more firmware updates for x5ii? i would like to see possibility to display album cover without HUD and ability to wheel volume without need of holding center button first. Also more visual themes would be nice. I remember many people (including me) did theme for original x3 and there is still almost nothing for x5ii.
btw i was experimenting with gain and low pass filter setting and discovered, that gradual filter and high gain sounds best to me? why is that? can somebody elaborate on those settings?
otherwise im pretty happy with purchase. im a bit disapointed with DSD and high res, which i expected to be audiable improvement over cd resolution but its not.
Jul 22, 2016 at 1:19 PM Post #5,469 of 7,088
I am also having settings of High Gain and Gradual.
I find high gain sounds better and more punch.
I find Gradual more cohesive sounding.
Steep felt like something's missing or got cut off.
Jul 22, 2016 at 2:39 PM Post #5,470 of 7,088
Gain all depends on the headphones impedance.
You guys probably prefer high cause' it's better to have a little too much gain than less to get the full response of a speaker.
Just be sure you're not distorting the sound which will blowout the speaker from pushing it too hard.
My 600's need the high gain.
I like to use the steep setting for crappy recordings/mastering like the latest brick walled music that are too sharp for my ears.
And the gradual for music I find already pleasing
Jul 22, 2016 at 6:06 PM Post #5,471 of 7,088
I actually love steep filter on music, it brings so much more life into it
 Steep filter adds more treble, should be brighter.
Gradual filter decreases treble, it makes things smoother, I think you have them mixed up there
Jul 22, 2016 at 6:31 PM Post #5,472 of 7,088
OK. :)
Truth is I'm having problems lately with frequencies above 1K which is why I bought the X5ii (EQ capabilities)
I need much more help with a lot of recordings than both filters offer.
I thought I had done some ear damage until I realized my problem is the result of severe allergies.
This explained why one night my equipment can sound great and another not.
Jul 23, 2016 at 5:09 PM Post #5,473 of 7,088
am I the only one experiencing some issue with load time and just lag, freeze when I switch musics?
