[FiiO UTWS3] True Wireless Bluetooth Module/MMCX/0.78 2pin/QCC3020/TPA6140A2/ Bluetooth 5.0
Jan 28, 2021 at 11:23 AM Post #406 of 772
medi88
Hi, both are on the latest firmware, version 2.46. updated them a couple of nights back. again, this only happens when taking calls with my laptop, not with my phone or my DAP.
will try to reflash the firmware again..
@FiiO Willson I'm still having the same issue when calling with MS Teams on my laptop after reflashing the updated firmware. it makes it a bit disorienting as the sound will be slightly off centre.
what's confusing me is that when i listen to songs, videos in youtube on my laptop i don't have the issue at all.
Appreciate if anybody can advise if they experienced the same issues and how to solve it, if any or if it's something that i just have to live with.
Jan 29, 2021 at 3:51 AM Post #408 of 772
China
I received your question, we will test it and if there are problems we will try to improve it!
:beerchug:
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
Jan 29, 2021 at 4:29 AM Post #409 of 772
FiiO
Sponsor: FiiO
Guangzhou,China
Dear friend,
Could you please provide the operation system of your laptop to us so we could try to reproduce your issue? Your laptop has the Bluetooth function or you are using a Bluetooth adapter in your laptop?
Best regards
Jan 29, 2021 at 11:19 AM Post #411 of 772
medi88
Dear friend,
Best regards
Hi, I'm on WIndows 10, BUild Code W10X64 1803. My laptop has bluetooth built in.
Thanks!
Jan 30, 2021 at 12:57 AM Post #413 of 772
ClieOS
IEM Reviewer Extraordinaire
Mid Johor, Malaysia
I think it's an Android requirement for connecting to Bluetooth device, since their app is going to do that they need location services turned on
I think it is likely something to do with Bluetooth LE, which QCC3020 supports and needs location permission because parts of BLE is it's ability to be used as Bluetooth location tag.
Jan 30, 2021 at 9:19 AM Post #416 of 772
Ocelitgol
Previously known as stormers
NYC
@FiiO Willson is it normal for the modules to not turning off/disconnecting when inside the case if the case has no battery left? Because that just happened to me.
When I start to charge the case, then the modules disconnect like normal.
Jan 30, 2021 at 9:48 AM Post #417 of 772
theowbert
anyone know a good alternative to these as they don't seem to be coming to the Uk from amazon or others and no response to when and need to make my westone w4r wireless
thanks
Have you tried getting them from AliExpress? That's where I got mine from since I couldn't want to find out if/when an Australian retailer would have them in stock.
Jan 30, 2021 at 2:19 PM Post #419 of 772
ClieOS
Mid Johor, Malaysia
Normal. I have a few TWS that behave the same way.
