FiiO Releases the 3.5mm to 2.5mm Adaptor Cable L26
Discussion in 'FiiO' started by fiio, Nov 22, 2016.
  1. FiiO
    Dear friend,
    Can the 3.5mm headphone cable of the f9pro work if so? You are using the 2.5mm balanced cable +L26 with only sound from the right ear?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official http://www.fiio.net/fiio http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. AzraelAndrey
    Hello there.
    Nope what I mean is that i tried the balanced cable with a normal small adapter (2.5mm to 3.5mm) and I read that the other guy had the same issue like me and said after he bought the L26 cable everything was the way it should be. So I orderd the cable today and will wait and see how it's gonna work. I absolutely love the F9 PRO!
    Best regards,
    Andrey
  3. Lurk650
    It will work. Have no worries.
    AzraelAndrey likes this.
  4. ramenmeal
    I got this product, the left channel drops out a lot if I move my cable. Gonna replace it and see if its a common issue or just a defective unit. Amazon reviews suggest its a common issue though.
  5. FiiO
    Dear friend,
    The issue happens when moving your headphone cable or the port of the L26? We will also report to the engineer about that. Sorry for bringing inconvenience to you.
    Best regards
  6. SubMash
    Hi. Where are you getting ground for unbalanced signal? There are 4 pins l+ l- r+ r- and no ground. So are you using some filter on a negative connection to make ground out of it? Or using say left negative as a ground for left and right?
  7. DJ The Rocket
    @SubMash are you making your own converter then? The negatives are ground. Just short them together wherever.
  8. SubMash
    Sorry, I misread direction of signal. No problem already.
  9. Posma
    Can i use L26 with 2.5 mm balanced cable connect to mojo?
  10. FiiO
    Dear friend,
    If your balanced cable you use have the definition like :<----R-R+L+L-,you could use it with the L26.
    Best regards
  11. Posma
    My cable came with fiio FH1 IEM
  12. FiiO
    You could connect the 3.5mm cable for the FH1 directly or use the 2.5mm cable+L26 for the mojo.
    Best regards
  13. Posma
    Thnk u very much
  14. FiiO
