FiiO Q5, Flagship DAC/Amp, an Dual DAC, USB/Optical/Coaxial/Line in, share the same amp module with X7.
Discussion in 'Portable Headphone Amps' started by jamesfiio, Jun 21, 2015.
Tags:
10 11 12 13 14 15 16 17 18 19
  1. Zxzxxcxc
    Is it a dac designed for portable devices? Like 9018K2M?
  2. x RELIC x Contributor
    You can read all about it here:
    http://www.akm.com/file.jsp?id=273638
  3. howdy
    You should go with that option, they have a sound that never gets tiring.
  4. JamesFiiO Contributor
    Yes, it comes with a module ( for IEM ). and we have nothing to tell you about the release date cause it is too early .
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    HiFiChris likes this.
  5. JamesFiiO Contributor
    any suggestion about which bluetooth device has best sound quality and stable enough for HiFi ( without any noise, pause and noticeable delay )
  6. x RELIC x Contributor
    Not portable, but my Oppo HA-1 desktop amp has pretty good Bluetooth with good range.
  7. JamesFiiO Contributor
    will buy a creative E5 and test by myself.
    zzffnn likes this.
  8. nmatheis Contributor
    Range does not equal stability, though. A smartphone has a lot of radios that create interference that your Oppo doesn't have to contend with.
  9. x RELIC x Contributor
    Yeah, not a fair comparison. One of the reasons I really never use Bluetooth from my phone. :wink:
  10. ThatPhil
    Have you considered the new ESS9018AQ2M for the DAC
  11. JamesFiiO Contributor
    almost the same as ESS9018K2M, I have not idea why they release so many 9018XXX [​IMG]
  12. nmatheis Contributor
    It's ok if you turn on Airplane Mode and then enable Bluetooth, but that kinda defeats all the streaming services - just a wee bit inconvenient...
  13. earfonia
    Could you please consider Texas Instrument DSD1793 ?
    The unique thing from DSD1793 is that it is partly pure PCM ladder DAC (the first significant 6 bits), so not entirely Delta-Sigma DAC like most of the modern DAC chips that convert PCM data to bitstream. Ladder DAC is known for it's natural and musical sound.
    Thanks!
  14. WayneWoondirts
    Thanks for your answer.
    Thought that it would be too early. Thank you anyway.
    You guys keep up the good work and my money will keep landing in your pockets :wink:
    The Q5 appears to match everything I'm looking for right now.
  15. asdfg
    But I think that there will be bound to have certain issues such as in-synchronization between the different lines...
