FiiO Q5, Flagship DAC/Amp, an Dual DAC, USB/Optical/Coaxial/Line in, share the same amp module with X7.
Discussion in 'Portable Headphone Amps' started by jamesfiio, Jun 21, 2015.
Tags:
8 9 10 11 12 13 14 15 16 17
  1. HiFiChris Contributor
    @nmatheis:
    I also prefer a fine-grained volume control, imo the iBasso DX90's is perfect with attenuation steps of 0.5 dB over the whole adjustment range. Imo the FiiO X3 uses too huge steps in the lower regions so finding the dead-on volume you want isn't always possible.
    @JamesFiiO:
    One more thing: what kinds of inputs (besides a micro USB jack) will the Q5 have?
    I'm really hoping that it may get a digital optical input and also an analogue 3.5 mm Line Input for using it as Amp only.
  2. sodesuka
    Umm, if the title is anything to go by, it should have optical and line in, the line in is probably 3.5mm too considering the form factor.
  3. nmatheis Contributor
    I really like DX90 volume control, as well. It's very fine-grained, allowing sensitive IEM users to really find their sweet spot.
  4. JamesFiiO Contributor
    About the way to control the volume. both digital with display or analog with knobs are fine. with 3 gain control,  it is quite easy to find the suitable volume for your sensivitive IEM.
    also a volume knobs make it looks more like a audio gear but not other electronics.
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  5. nmatheis Contributor
    As long as I can use it with sensitive IEM, I'm happy James :)
  6. HiFiChris Contributor
    @sodesuka:
    You're right, reading the title hels sometimes. :-X
    @JamesFiiO:
    Could you please give us any further information about this question?
  7. earfonia
    Agree. I much prefer knob volume control. It is much easier to control, as knob sensitives to the turning speed. And it looks much more classy, as you said, not like electronics toys with display. I hate volume control with push button.
  8. WayneWoondirts
    I also think that a knob would be better. much easier to set the right volume.
    Also @JamesFiiO are there any plans to release a new desktop DAC?
  9. Dobrescu George
    I, for one do like full digital better.
    This is meant to be portable, and I think that volume knobs are much more prone to damage in general due to their more exposed nature than buttons.
    HiFiChris likes this.
  10. zzffnn
    James,
    I like the DLNA idea. Without it, I would not buy Q5 even if you put 8 channels of DACs there :p
    Bluetooth has improved significantly over the past 5 years, please consider it again. You probably should not make a decision based on a 5-year-old research on digital products.
    Creative E5 is a powerful amp/DAC/ADC with Bluetooth. You may learn from their design.
    I prefer to have more amp power than that offered by X7, if I am buying an amp/DAC again.
  11. earfonia
    It is not analog volume pot. Please read James thread on the first page. The volume control is using PGA2311 chip. The volume knob is to digitally control the PGA2311. And the volume knob is protected like in the shown picture. So I guess should be durable.
  12. ClieOS Contributor
    Remember that full digital volume control can only work by eating into the digital bit of the music. For example, every -6dB equals to the loss of one bit. Think of the effect it will have if you are listening to a 16bit file with low volume, you could very well listening to 12bit music at the end. On the other hand, PGA2311 is actually still an analog volume control, but only the volume adjustment is digitally controlled. Therefore it offers near perfect volume match on both channel as well as very precise steps (0.5dB), but without any reduction of the digital resolution. It is pretty much an combination of the best of both world.
    The actual working is usually like this: an small ADC is monitoring the pot, when the pot turns, the ADC converts the actual turning into digital signal and send it to PGA2311, then the chip sets the volume accordingly using the tiny resistors network inside the chip.
  13. earfonia
    That's right!
    What I mean is, Q5 is not using the conventional carbon track analog volume pot, but the more modern PGA2311 analog volume control.
  14. JamesFiiO Contributor
    The hero always apear when I need help [​IMG]
  15. Dobrescu George
    Nice data!
    I had forgotten to investigate in depth what PGA2311 does.
    Sidenote: I wonder why there are 2 volume pots?
