FiiO Q5, Flagship DAC/Amp, an Dual DAC, USB/Optical/Coaxial/Line in, share the same amp module with X7.
Feb 2, 2016 at 3:26 AM Post #364 of 3,173
  just posted the final design of Q5.
Looking really nice.
i think it would also be pretty cool if you guys could design it in such a way that would allow the attachment of some kind of "blanking" module, so that the user doesn't HAVE to have an amp module attached if he/she only wants to use the Q5 as a DAC...could possibly also reduce the footprint
Feb 2, 2016 at 3:35 AM Post #365 of 3,173
yes, we already  design a " blanking " module.
BTW, the Q5 will be deliveried without any amp module so people can choose the amp they want.
Feb 2, 2016 at 3:41 AM Post #366 of 3,173
I think that would be a pretty smart move.
Is there any indication of when the Q5 might be available? The reason I ask is because I'm currently looking at getting a DAC for my desktop...but it MUST have an optical input as well so that I can easily switch between my PlayStation and desktop. So far the Schiit Modi 2 Uber seems like my best option (especially that you can physically select between different inputs, as opposed to having to disconnect them).
I'd much prefer to buy another Fiio product though
Feb 2, 2016 at 3:50 AM Post #367 of 3,173
the ETA is before X'mas
Feb 2, 2016 at 6:19 AM Post #369 of 3,173
James, do you think your engineers will be able to implement the digital USB DAC volume control from the host (OSX / Win) for this amazing DAC/AMP?
Some DAPs like AK240 or Ibasso DX80 works great, also some DAC/AMPs like Creative Sound Blaster X5 works.
But the USB volume control for X5 / X7 is unfortunately not working ;(
Sound quality from this AMP and its DACs will be likely very good so this will be great for use as external soundcard for a lot of users for their computers. Thanks for any info!
Feb 2, 2016 at 6:52 AM Post #370 of 3,173
As sort of a Sabre fanboy
 I am not 100% happy with the move to AKM (which often tend to be rather on the smooth, "analogue" side), but if implementation is done well, I hope that the final sound will be neutral, transparent and detailed.
Btw, do you have any information about the amount of volume steps, attenuation size per step in dB and the gain settings, @JamesFiiO?
Feb 2, 2016 at 7:08 AM Post #371 of 3,173
Q5 will used XMOS USB receiver which is included in AK240, so I guess it should work as AK240.
Feb 2, 2016 at 7:14 AM Post #372 of 3,173
should be 0.5dB if it is necessary. gain settings is two or three.
Feb 2, 2016 at 7:18 AM Post #373 of 3,173
0.5 db for every step all over the whole attenuation range would be really nice. :)
Any information about how many attenuation steps will be there?
Three gain settings would be excellent. My suggestion: one negative gain (at least -15 dB or even lower for very sensitive IEMs) setting, one zero gain setting and one positive gain setting.
