thirtyCruisers
Has anyone taken apart the amp module? My 3,5mm on the AM3A seems to be almost dead. I think I need to resolder the socket, but I don't see a way in. Thanks.
I use predominantly IEM'S, and the amp module that comes with it is fine
Dear friend,Has anyone taken apart the amp module? My 3,5mm on the AM3A seems to be almost dead. I think I need to resolder the socket, but I don't see a way in. Thanks.
Wow, thanks! Couldn't have asked for a better response.You may check if this instruction could help: http://fiio-instruction.oss-us-west... of How to Disassemble the X7 Amp Modules.pdf
But surely the Q5 comes with the AM3A anyway? Mine did, and that definitely has very, very little to no hiss depending on the source recording or volume setting.I read AM3 without A at the end adds some hissing when low impedance IEM connected. So does jumbo A5.
Dear friend,Guys, when I use the DAC under Mac OS X (Catalina, Sierra, Mojave), when I select under Midi settings the format of the audio, if I left 32 bits, 384 khz, applications like Microsoft Teams or Skype for Business crashes as hell. I need to go down for 192 khz, otherwise, again, some app crashes. I tried on different Mac OS X versions and different Mac machines just to be sure that its not something wrong with the USB port or just one machine issue. @FiiO Any thoughts?
Audirvana works correctly, I know that its something regarding those applications but its very stressful as I use the dac mainly at work and don't be able to use it properly makes me think to sell itDear friend,
Does the same issue happen in other music software like Audirvana?
Best regards
Dear friend,Audirvana works correctly, I know that its something regarding those applications but its very stressful as I use the dac mainly at work and don't be able to use it properly makes me think to sell it
And how do you do it? I mean, how are you trying to connect the Q5 with the Sony? Cable? Because you don’t have an interface to pair de Q5 to the Sony as far as I know, just through cableI impulse-bought a pair of SONY WF1000XM3 bluetooth earphones recently without doing a lot of (read: any) research on codec compatability. They connect to my phone via AAC with no problem and sound, yep, pretty good. To my surprise however my Fiio M9 just throws up its hands at trying to connect with them. My Fiio M11 makes a good fist of it - but all it can finally muster is a link via the the, ahem, not-stellar SBC codec. The Q5 though - I kinda hoped - might be able to haul itself up to connect to them via the AAC codec - but no, not a sausage, not a squeak. It may be, it may well be, of course, that the Q5 was never designed to connect via AAC to something like the Wf1000xm3. So is this a hiding to nothing - or are there arcane pairing rituals I can be initiated into?
Exactly, the Q5 is designed to connect to the unit (smartphone, dap, etc) via BT, not the headphones ..And how do you do it? I mean, how are you trying to connect the Q5 with the Sony? Cable? Because you don’t have an interface to pair de Q5 to the Sony as far as I know, just through cable
I will say that this function would be marvelous tbh xD because you can have your DAC in your pocket, pair with the headphones/earphones and a phone or any other source and just play the music without cables but well, it’s just an ideaExactly, the Q5 is designed to connect to the unit (smartphone, dap, etc) via BT, not the headphones ..
