FiiO Q1MKII- Native DSD Support, XMOS USB DAC chip, DAC AK4452, 20 hours
Apr 10, 2020 at 9:17 AM Post #796 of 832
HiFi47
Yogyakarta
I have this setup: A35->Q1mk2->HD6xx via balanced - cannot hope for better. I use a custom WMport-to-microUSB cable, the L27 also works the same (I have both, but had bought the custom one earlier, so it's stayed attached) So go for it!
The A35 takes at least a 400GB card (I have it) reportedy 1TB cards also work well. There is/might be a lmit on the number of files, though, I'm not sure about it.
Thanks Roger for your your very fast response and your impressions!
Is it still possible to use the equalizer? And will the q1 read DSD files properly?
Apr 10, 2020 at 11:04 AM Post #797 of 832
WilcoRoger
Equalizer - no, the Sony just provides the raw data stream to the Fiio, that does the heavy lifting. If you want to use the DAP’s equalizer, you’ll need to connect to the analog input of the Fiio. Then the Sony’ DAC will do the lifting.
DSD - no problems at all.
May 26, 2020 at 9:39 PM Post #798 of 832
H T T
I am looking to purchase a few back up lightning to usb mini cables for my Q1Mark II. I tried Amazon for a third party cable. Two epic fails in a row. Does FiiO sell cables?
May 27, 2020 at 4:18 AM Post #799 of 832
Steve Guppy
England
They definitely do very good cables for Android use. However, i haven't seen a lightning variant, but then again, i haven't looked. But Penon Audio definitely do a good range of usb cables
May 28, 2020 at 2:35 AM Post #801 of 832
FiiO
Sponsor: FiiO
Guangzhou,China
Hi,
Which country are you located in? You could contact support@fiio.com for help.
Best regards
Jun 16, 2020 at 8:55 AM Post #804 of 832
tiamor988
Malaysia
Woot woot.
Jul 24, 2020 at 2:22 AM Post #808 of 832
FiiO
Sponsor: FiiO
Guangzhou,China
Chapter Ten: Q1MKII
Today we would come to the second new product in 2017, i.e. the Q1 Mark II (Q1MKII). Our old users may know that although our first product was a speaker, it is actually the portable amps that help us make money. This is the reason we have never stopped the introduction of new amp products.
The Q1MKII is somewhat of a pioneer in terms of the ID design in 2017. The one who has watched the Launch Event and series stories of the M15 may notice that the flagship M15 has inherited the exterior style of the Q1MKII, especially details of the top and bottom part which has a similarity of 90%.
From the name, Q1MKII, we can easily get that the Q1MKII is the upgraded version of the Q1. But what are the other differences apart from the obviously similar looks?
The most important thing is that the Q1MKII supports iPhones by wining the MFi certification. In fact, we had announced our product strategy at the 2016 Guangzhou Headphone Expo, one of which was the MFi strategy. In short, we wanted to develop a series of audio accessories for iPhones. By the way, for iPhones which build connection through the Lightning port, be sure to check the MFi certification. Otherwise, connections may fail once the iOS is upgraded.
Secondly, the Q1MKII is equipped with a 2.5mm balanced output which you might be more familiar than ever before. In fact, the balanced output on the player/amplifier/headphone has not been introduced very long, but the popularization is quite fast. So our Q1MKII would not go far behind.
Furthermore, most of the amplifier products like the headphone amplifier, uses a potentiometer to control the volume, which is efficient combining with the volume indication itself, and easy to grip. However, it also has quite a few shortcomings. One is that the channel imbalance at low volume because it is difficult to do well. The second is that problems due to long-time using such as noise and other credibilities when adjusting the volume may happen to it. Therefore, for the Q1MKII, we have adopted a new type of ADC volume adjustment technology, on which the audio signal does not go through the volume knob, so there will be no problems such as noise and channel imbalance yet meanwhile the advantages of the volume knob can be kept. Later, this kind of technology is widely applied to many FiiO products which has formed a characteristic of FiiO audio products.
Last but not least, FiiO's DAC/Amps had always been using the USB decoding chip that is with relatively bad poor extensibility and lower supporting formats. However, starting from the Q1MKII, we have adopted the XMOS scheme with the best performance and function ability recognized in the industry. Therefore, the supporting music format of the Q1MKII has soared to 384K/32B, and it also supports native DSD256. This was a great progress based on the Q1.
As for other aspects that were developed and optimized on the basis of the Q1, I would like to rule them out. I believe that from the introduction of the Q1MKII, you can see some of the designs began on the Q1MKII, including the ID design, function, and exterior style, have been continuously applied to FiiO's subsequent new products. This also fully proves the success of the Q1MKII on designs.
To conclude, the Q1MKII is not only a pioneer in technology, but also in the market. Since its listing in 2017, it has continued to sell well in domestic and overseas markets, creating good economic benefits for us.
Aug 10, 2020 at 4:21 PM Post #809 of 832
CarlosAudio51
Wisconsin, USA
I have tried 2 or 3 different micro USB to micro USB OTG cables to pair the Fiio to my Android phone. None of them except for the Fiio ML06 cable can prevent the Fiio from getting power off my phone battery. So, in that regards, it's working as expected. But I'm looking for essentially a longer ML06 (4 to 6 ft long), or any equivalent micro USB to micro USB OTG cable that will not discharge my phone battery. Does anyone know of any?
The ML06 is too short. Only useful for stacking the Fiio with the phone back-to-back, which is kind of terrible since the stacking bands cover half my phone's screen.
Aug 11, 2020 at 4:03 AM Post #810 of 832
FiiO
Sponsor: FiiO
Guangzhou,China
Dear user,
For connecting some mobile phone or players with micro usb/type c port, you would need the cable with ID pin to ground(micro usb/type c port) in order to avoid using the power from your phone.
Best regards
