FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
89 90 91 92 93 94 95 96 97 98
100 101 102 103 104 105 106 107 108 109
  1. stenog
    You will loose all Tidal downloads because you will erase the app. Don't know about your EQ settings but I would assume it would be the same.
  2. frustration101
    I had previously sideloaded Tidal with MQA support from a third party. Same with the Sony headphones app. Anyone else done that and avoided problems following update? Scared to mess those apps up!
  3. stenog
    I think you can update without any problems but i don't think you can do a factory reset. But to be honest i haven't tried it on the M9.
  4. frustration101
    Hi gLer. Have you updated to the latest firmware? Did tidal still work properly afterward?
  5. frustration101
    Has anyone who already had the latest Tidal app and Sony headphones app side loaded from a third party updated to the new firmware? Did you have any problems or all good?
  6. frustration101
    Bit the bullet and did the firmware update. Happy to say all ok. Didn’t effect Tidal. A toggle of Bluetooth on/off and the Sony headphones app is ok too. :dt880smile:
    TheStalker79 likes this.
  7. deadhead12
    Got a new balanced cable so I can at least listen to my M9, but I can only listen balanced. It still won’t output to a single ended cable.
  8. Brooko Contributor
    Just surmising .......
    This could perhaps be some of the problem. My advice - contact the people who sold you the device, and see if you can activate an RMA. At the very least they need to test the device and see what the cause is. As to whether you are covered or not - I guess that will come out when they know what the cause is. In the interim - asking here is not really going to help. A professional needs to see if the issue is software or hardware.
  9. deadhead12
    I was posting here to see if anyone else was having a similar issue since my device was working fine before the firmware update. I know the drop could be a factor, but it worked flawlessly using both outputs for a month after I dropped it. If I’m the only one having this issue then it’s likely hardware related, probably due to the drop.
  10. ericlhyman
    I]
  11. ericlhyman
  12. deadhead12
    My device came with a coax dongle in the bottom of the box that I just found out about yesterday. Perhaps that’s what you’re looking for?
  13. Vahur
    Hi!
    Would like to ask that is it possible to connect this device to Android phone via USB cable to work as DAC on phone? Or is only possibility to connect with Bluetooth?
    Searching currently for my first DAC for Shure SE846. Would like to have possibility to use same device with my phone as DAC and also my computer. But receiving signal via Bluetooth would also be nice as M9 has to use it with my BT headphones.
  14. TheStalker79
    I've just hooked up my phone via an OTG cable to the M9 and you can indeed use it as a DAC/amp. All you have to do is select USB DAC in the audio options. I didn't know you could do that!
    Vahur likes this.
  15. Vahur
    Great! Thank you for testing it!
    Seems like have to make an order for it then :-D
