FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
86 87 88 89 90 91 92 93 94 95
97 98 99 100 101 102 103 104 105 106
  1. gazzington
    I'm thinking of buying a m9 as I recently bought the m6 and love it. I notice you are fond of bands such as winter sun. What iems under £450 would you recommend for such music?
    Dobrescu George likes this.
  2. ZoneRanger
    I had the issue with Tidal crashing after the latest update. Installing the latest Tidal APK from Fiio fixed it.
  3. Daiyama
    FiiO please work on your update server or delete the online update function, currently this only leads to frustration.....
  4. gLer
    Why? Works fine here. Every OTA update has installed first time. You don’t have to update as soon as one is available. Wait and see if there are any issues before installing.
  5. Daiyama
    Download via PC is also at 28-32 KB/s. LOL
    I will wait till the morning....
  6. Dobrescu George
    Ayy, Wintersun is one of my favorite bands :)
    For my personal taste, and judging from everything I heard to date, it is hard to make a clear choice.
    I mean, I know so many IEMs in that price range, that it would be hard to pick just one, but for Wintersun in particular, it is good to have good layering, quick overall sound, quick bass, and clean overall sound, with some engaing upper midrange for guitar riffs.
    At this moment I am wearing Accoustune HS1650CU, and I can only say that I am in love with how Wintersun sounds played from them
    Some folks really like iBasso IT04, others like Final E5000. IMr R1 is also fairly sweet. I really need to ask you how you'd like it best to sound, because depending on whether you want it to be colder, warmer, more technical / analytic or more organic / natural, I can more easily recommend a good IEM :)
  7. gazzington
    I love winter sun too. I suppose I like warmer rather than cold with an organic sound
  8. frustration101
    Does the whitelisted Tidal app support master quality now? (I have it installed from a third party source at the moment)
  9. bowei006 Contributor
    Is your main issue that the download is slow?
    @FiiO
    Stagger your pushes of OTA by region/serial to reduce load on your server. Either pay for more servers around the world and do some dynamic load balancing or ability to spin up more servers as need be (AWS etc) or stagger them.
    Staggering means you use some methodology to NOT have everyone try for an OTA update at once. If you can't do region based staggering, do a random serial based one for example
    Day 0, hour 0: Push OTA to devices serial 0-200
    Day 0, hour 4, serial 201-400
    Day 2, allow full unrestricted all serial downloading at any time.
  10. stmat72
    After installing the latest firmware update, Tidal no longer recognizes any of the download files stored on the SD card. It tells me I have no downloaded files even though the files are all still on the card. Is there a way to fix this so I can access the files again? I live in a rural area with very poor internet access so I rely on the offline files to be able to listen to my music.
  11. loungecat
    Hi Markolav.
    I had the same trouble If you go into settings, then, Apps,then Tidal I cleared The Cache and user data!(I think you will lose anything you downloaded can't confirm)
    That worked for me,I don't have any Music Downloaded to sd card yet,so just had to re-Login to Tidal :)
    Markolav likes this.
  12. Starlights
    is there anyone who has shutdown itself issue when playing music after upgrading to fw 1.04 ?
    mine suddenly shutdown itself twice when playing songs. i wonder why
  13. Atreides2001
    Can you add Google Play Music and eventually Youtube Music apps? That would give me access to my uploaded library alongside my local music. Thanks, its an amazing device.
  14. Sven2015
    Is there a new FW online? Any link for me?
  15. Daiyama
