FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
93 94 95 96 97 98 99 100 101 102
104 105 106 107 108 109 110 111 112 113
  1. Tsukii
    Bought my m9 and sk9 case from jindong,is true that there is no sd card cut,but i can easily remove the case just by draging the screen down,or even with a cable connected you can pull the case out,maybe yours was a defective unit?
  2. EarlytoBed
    Yes it is, but more than the size seems to be a codec issue (I don't really know, just making guesses).
    Thanks dharmasteve!
  3. Richter Di
    Can anybody verify that you can not get 24 bit out of the FiiO M9 SPDIF?
  4. Gary_W
    Thanks TheStalker79 - I didn’t know about this site so this is really helpful.
    Just ordered one - seen the comment above regarding it being a mega tight fit once I’d pulled the trigger..... I’m not taking the card in and out (I load songs via the cable) so, whilst this tight a fit isn’t ideal, I’ll hopefully be ok with my use.
    TheStalker79 likes this.
  5. dharmasteve
    It is a tightish fit and the first time I took it out of the case I had to be patient. But there's a little gap at the top and with the right tool and perseverance the M9 comes out slowly. It does look good and because the M9 has a pre-fitted screen protector it does a good job of looking after this great sounding player.
  6. divideby0
    Just got my M9 today. Love the player and it sounds great. I'm curious though - how do you get the microSD card out to upgrade to a bigger one?
  7. alwass89
    Is anyone using this player with a 512GB micro SD card? If so, can you please let me know which one you are using?
  8. FiiO
    Dear friend,
    Did you test by yourself or? What's the module name of the DAC you are using?
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  9. FiiO
    Dear friend,
    Does the issue happen in both offline and on-line music files? What about when turning off the wifi? Did the issue happen before updating the firmware? Are there any play mode option in the Tidal app?
    Best regards
  10. Sven2015
    I have this one and it's working fine, but the internal file manager crashes due to file limitation (it seems it crashes with more than 20.000? files maybe less).
    Samsung Memory MB-MC512GAEU 512 GB EVO Plus Micro SD
    (EU version but you can search the correct one for your country)
  11. Richter Di
    Yes, I did test it by myself.
    I am using the @Jan Meier Soul: http://www.meier-audio.homepage.t-online.de/soul.htm
    The Soul uses a Cirrus Logic WM8804 S/PDIF Digital Interface Transceiver https://www.cirrus.com/products/wm8804/ and a Cirrus Logic WM8741 24-bit, 192 kHz, Advanced D/A Converter with Advanced Digital Filtering https://www.cirrus.com/products/wm8741/
  12. deadhead12
    So I contacted Fiio regarding my issues and I was planning on mailing my device to Fiio for inspection/repair this afternoon. I removed my SD card and charged it on Friday as I thought I would mail it out then, but I didn't have the opportunity to make it to the post office. I turned my device on about 30 min ago to check the battery, fully expecting it to read 80% or so but it said 98%! Furthermore, the little 2.5mm balanced icon was gone! I plugged in my computer speakers in the 3.5mm jack and it's working! I have no idea what happened or why 1) my battery seems to be draining normally and 2) my 3.5mm jack is working again. I guess my device just needed to rest a bit.
  13. Richter Di
    @FiiO , any news?
  14. Buzzz
    Hello, I hope I am in the right topic for that, excuse me if I'm not.
    Would it be possible to add "radio paradise" to the white list?
    Thanks in advance.
  15. Sven2015
    @FiiO
    Any news about 3rd party music player such my preferred "gonemadplayer"? Your FiiO player is just standard and many things missed..... pls. open your player for a better music app.
