21qz
- Mar 10, 2011
Well I’ll be...
Patiently waiting for R3 comparison...
Wait am i hearing this correctly? you can download songs or playlists to this from streaming services like spotify and tidal and listen to them offline as i would with my iphone?
GTFOH .... Isn't that what Hiby was trying to do??
Applications need to be whitelisted. Even if you put the apk on the device, if the app isn't approved it won't run. And AFAIK there's no video app whitelisted, so no VLC/Videos won't work.Just asking a question, when they (Fiio) said in their FAQs on their website - “The M6 runs on deeply customized system. To ensure system stability, only certain apps in our white list are allowed to be installed.” Only certain apps are allowed. Others would take to much space? Or the M6 would not support an app/ or whats in it. And if not, theoretically if I get VLC or a video player in apk and install it on the M6 would I be able to watch videos?
Yes they did whitelist ES File ExplorerOk can you watch videos? To a degree yes. ES File Explorer may be whitelisted. It is on the M9. If small video files are transferred to the 2gb built in memory (maybe to an SD card too), then you can play tiny but clear videos by using the inbuilt ES File Explorer Video Player. You can also get Google if they whitelist the ES File Explorer app. You can run a working Youtube by typing Youtube into the Google search. It shows a tiny Portrait aligned video but very clear. Because there are so many original live recordings on Youtube it is a very valid use of the M9 and hopefully the M6. Like I say Youtube sounds excellent, although it does not synchronise with the video movement and mouthing very well, but nevertheless sounds great. If they don't whitelist ES File Explorer then forget it.
I'll be interested to hear sound comparisons between the M6 with the sabre DAC chip and the M9 with dual AK4490 DAC chips. The dual AK4490s in the M9 produce a classy, vibrant but very smooth sound, a sound I love. I find the sabre chipped little DAC I presently have to be more energetic, dynamic but not fatiguing. Incredible price for what this little M6 DAP seems to offer.
